Wolfe 4thgen bolt in 4 point, fit thirdgen?
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
I have an opportunity to buy a Wolfe 4 point bolt in, need to know if it will be possible to fit in thirdgen, the interrior floor pans are almost the same, anyoneusing one or see an issue?
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Wolfe 4thgen bolt in 4 point, fit thirdgen?
If the price is good, give it a shot. The floors and rear wheel wells are close enough that it would be really close to fitting. I could see an issue clearing the 3rd gen interior on the rear wheels wells.
Engine: 4.3 Turbo
Transmission: 4L60
yeah $200 for a $600 cage is pretty good i think
1 Post
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Please keep us informed.
I was 2 seconds away from getting one on my '02 but backed out at the last seconds. I would love to put one on my third gen though.
Engine: 4.3 Turbo
Transmission: 4L60
k so it does fit pretty well. only modification needed is the passenger side front mounting plate.. needs to be bent (rolled) over to adhere to the contour of the thirdgen front floor panel. otherwise its a nice fit. i should have pics up in a few days... i didnt get the rear bars however.
Engine: 4.3 Turbo
Transmission: 4L60
the issue i was telling you about is the front passenger door bar mount.. not the passenger main hoop mount
this is the picture from wolfe's site.. this is what i have currently..
you can then add in the rear bars... like this.
this is a picture of all the bars bolts together..
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
what? no.. i have the main hoop and the driver and passenger side door bars.. Wolfe call it their 4 point roll bar. you can add the rears to make it a 6 point.. to which i do not have currently..
Engine: 4.3 Turbo
Transmission: 4L60
Oh. Typically a 4-pt is the hoop & 2 rear bars. Door bars added to make make it into a 6-pt. Never seen a 4-pt made of the hoop & door bars. Odd way for them to redefine what is the typical 4-pt design. Go look at ANY other manufacturer & a 4-pt will be the hoop & rear bars. Zero with hoop & door bars.
i just sent them an email asking if i can buy just the rears since this guy i bought them from didnt have them.. hopefully they arent too expensive.
Car: GTA
You could always get rear bars from other places, or if you have a rear seat you could get the Jegs Seat Saver bars so that rear seat passengers heads would clear the rear bars better.
Engine: 4.3 Turbo
Transmission: 4L60
no i need the wolfe ones, since they are bolt on at the top of the hoop, they will just slip right on, then i drill the rear deck and attach the backing plates.. very simple
im almost done, should be done today.. i'll post pics of how i modified the front door bar plate too..
Engine: 4.3 Turbo
Transmission: 4L60
Well it's in and done, great Fitment, only real issue is as I mentioned before about the front passenger door bar mount needing to be modified. I'm at work right now and pics are on my iPhone.
Anyone know how to post pics on here from an iPhone?
Don't know how to do that yet.
Car: 87' IROC
Whats the reason for the roll bar? I can't imagine it will pass any sanctioning bodies. And I can't think of another reason to have a bar. What an interesting design.
Very interesting.
Engine: 4.3 Turbo
Transmission: 4L60
k here we go.. these were taken right after i bolted it in.. i had not cut the carpet yet because i wanted to show the mounting areas
driver side looking down
passenger side rear
this is the front passenger door bar mount that needs modified.. you can see i roll it over to match the contour of the floor pan.
passenger side rear
Engine: 4.3 Turbo
Transmission: 4L60
ill take finished pics tomorrow
fits pretty nice.. the kit doesnt actually come with under carriage mounting plates.. just some over sized washers.. so i made my own 1/4" thick plate steel under carriage mounting plates.
Engine: 4.3 Turbo
Transmission: 4L60
A little heat, a dead blow hammer and a round log of wood
Terrell351
06-13-2021 01:13 PM
hectre13
08-26-2015 08:17 AM
