Guys , I have Serious problem... PLEASE HELP
Old 08-29-2008, 02:57 PM
BustaZz's Avatar
I have a problem. Does anyone have an idea of what could be causing my car-engine to suddenly stop while driving, afterwhich a light goes on saying "Service Engine Soon". After that I have no problems starting the engine. The car is 2500km after a full service, without a change of valves and shaft. Also I notice it looses engine oil, but there's no smoke from the exhaust-pipe. Any advice or ideas?
Old 08-29-2008, 03:07 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
Re: Guys , I have Serious problem... PLEASE HELP
The check engine light comes on because it stalls. When did this start happening. what type of driving, is it random, etc as much info as possible
Old 08-29-2008, 03:59 PM
BustaZz's Avatar
I'm driving it quiet lightly, it's happening mostly in the city, where I rarely pass 2000 rpm, the steering wheel locks, brakes become hard, the engine stops suddenly...
Old 08-30-2008, 01:51 AM
nimrod_sixty9's Avatar
Car: '91 RS Camaro
Engine: 5.0 TBI
Transmission: Manual
Axle/Gears: 3.08
Sounds like the distro cap...
Old 08-30-2008, 02:09 AM
GMLSX's Avatar
Car: 1998 Slow
Engine: Too Small
yea, the engine dying is causing that...
and you say your losing oil? your losing oil pressure, or you mean your car is just burning oil?
do you have to add oil frequently? could have other issues if so.
Old 08-30-2008, 10:34 AM
BustaZz's Avatar
Hm , nope my Oil Presure always stay to maximum (420kpa) think burning oil , but from exhaust its no see any smoke ... i drive with Mobil1 Rally Formula 5W-50
Old 08-30-2008, 01:17 PM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
your oil pressure STAYS at maximum? i've actually never seen my gauge go up that high just poured some new 10w30 in that 70kmls engine..
Old 08-30-2008, 04:49 PM
Icarus 402001's Avatar
Car: 92RS
Check for codes. Jump A and B (top right slots in ALDL, found under steering wheel) with a paper clip; turn key to ON--DO NOT START. Count number of times check engine light flashes (read it as a 2 digit number).
Cleotiz
01-06-2018 08:56 PM
aaron7
08-17-2016 06:02 PM
PestilenceIV
08-20-2015 03:32 PM
Street Lethal
08-14-2015 08:25 PM
Zachattack0925
08-12-2015 09:52 PM
Quick Reply: Guys , I have Serious problem... PLEASE HELP
