Tbi heads and chip
Old 09-11-2016, 03:08 PM
Hk88's Avatar
Car: 1988 Chevy camaro
Engine: 5.0 v8 tbi
Tbi heads and chip
Hi I have a 1988 Chevy Camaro 305 Tbi I am planning on doing a head swap from a 87+ tpi It is a 081 casting head I wanted to know if it would work with my stock chip for a week or 2 till I can order my custom chip?
Old 09-12-2016, 07:26 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: Tbi heads and chip
Are you changing the cam as well or just the heads?
With just a head swap, I don't see any reason the stock chip wouldn't be fine for now. I do suggest a cam swap if you aren't though.
Old 09-12-2016, 12:28 PM
Hk88's Avatar
Engine: 5.0 v8 tbi
Yes I will be putting in a lt1 cam in there out of a 94 z28 I know the chip would support the cam for the time being but I needed to know if it would support the heads.Would my 305 injectors be able to support those mods for the time being till I can get the 350 injectors and custom chip for the mods and 350 injectors?
Old 09-14-2016, 03:33 PM
Schurkey's Avatar
The greater question is why you're wasting all that time, money, effort, and enthusiasm on a 305. If you're intent on computer-tuning anyway, stuffing in a 350 or larger engine is almost without downside.
It's hard to argue with 50+ ft/lbs of torque, at about the same or lower rpm.
Old 09-14-2016, 04:35 PM
Hk88's Avatar
Engine: 5.0 v8 tbi
I am pretty sure that my t5 tranny would not be able to handle the torque of a 350.
Old 09-15-2016, 03:03 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Lots of folks on here have done it. Depends entirely on how you drive the car
Old 09-15-2016, 03:13 PM
Hk88's Avatar
Engine: 5.0 v8 tbi
Yes you are right but I use this car as my daily driver I rather make less power but have a peace of mind that everything would be ok and I don't drive the car hard but I like to get on it once in a while everything considered it is a 28 year old transmission I would rather not take the risk.
Old 09-19-2016, 08:12 AM
3rdgenmaro's Avatar
Car: 88 IROC
Id just get the chip at the same time. You are already getting one, so why risk it? Get everything and do it all at once
Old 09-19-2016, 02:18 PM
Hk88's Avatar
Engine: 5.0 v8 tbi
Yes you are right that's what I am going to do.
deaddds
09-18-2017 08:05 AM
Bald_eagle_machine
08-27-2016 10:24 PM
lowlifepunk
08-23-2016 03:49 PM
ChrisMPG
08-21-2016 10:44 AM
shaynecastongua
08-13-2016 11:12 PM
Quick Reply: Tbi heads and chip
