Help! Is $375 fair for new MAFsensor instaled
Old 11-16-2001, 03:13 PM
blkform88's Avatar
I took my 305tpi bird to the shop because it was dying whenever I slowed or stoped. They say I need a new mass air flow sensor and it will cost me $375 with labor. Does this sound right. It is kind of high. Could I do this myself. I am no mechanic but it doesn't look that hard.
Old 11-16-2001, 03:25 PM
89IROC5.7's Avatar
Car: 89 IROC
Engine: 5.7 TPI
Transmission: A4
I think you can get them rebuilt for under $200 at autozone and it couldn't be easier to put in. You should be able to put in a MAF in literally under 5 minutes.
Old 11-16-2001, 05:38 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
auto zone has em for 140+exchange core,and anyone with a noggin can put it in
Old 11-16-2001, 11:23 PM
breathment's Avatar
well actualy all u need is a screw driver
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old 11-17-2001, 11:24 PM
Vader's Avatar
88,
Or you can get a brand new, warranted Wells SU-145 MAF for about $170.00 and never worry about your MAF again. The only operational difference is that the Wells MAF flows more than even a gutted Bosch MAF.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old 11-17-2001, 11:45 PM
Guest
Guest
Posts: n/a
Vader, you forgot to say its a better unit as well. Or at least thats what you keep saying.
Old 11-17-2001, 11:46 PM
breathment's Avatar
ah vader, 6666 post!!! do something!!!
- David
Old 11-19-2001, 12:25 AM
blkform88's Avatar
Thanks for the input. One $200 part, two screws, and $175 labor. No thanks. I'll do it myself. With my Haynes manual I can do anything! Ha.
Vader, Where can I buy the Wells MAF. This sounds the best to me. Hopefully I could get it locally and not have to wait for shiping. I want to bet my Bird back in action.
Old 11-19-2001, 01:39 AM
Vader's Avatar
BF88,
Any auto parts house that sells Wells/Conrad parts either has one or can get it for you. If you cannot find a supplier, you can check http://www.wellsmfgcorp.com/ for a distributor in your area.
Max,
I think the design of the MAF is better, since it uses the more modern thick-film sensor and flat metal matrix in place of the dual screens. The fact that is has a larger I.D. and no heat sink fins and sampling tube to restrict air flow can't hurt either. The design is basically "borrowed" from the LT1/LS1 MAF design.
Later,
Vader
Old 11-19-2001, 02:54 AM
Jza
Jza's Avatar
<font face="Verdana, Arial" size="2">Originally posted by blkform88:
With my Haynes manual I can do anything! Ha.</font>
That's the spirit! This site has done it's job!
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
RedLeader289
01-22-2016 03:05 PM
Dyno Don
17
11-02-2015 11:43 PM
NinjaNife
08-23-2015 11:49 AM
Quick Reply: Help! Is $375 fair for new MAFsensor instaled
