performance guru Questions
Old 04-24-2007, 11:22 PM
woodstock16's Avatar
Car: 1985
Engine: lg4
Axle/Gears: ????????
I own an 85 LG4 camaro i was just wondering how much it would help and how much faster it would be if I got a CCA-12-212-2 from comp cams,a EDL-2101 for an intake manifold, SUM-G9006 for headers,and Motive Gears GM 7.5" & 7.625" Ring and Pinion Set with a 3.42 gear ratio?
alltogether its only 600 bucks i already have it odered, will it be worth it?
Old 04-25-2007, 04:16 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: performance guru Questions
that will be about as fast as if you were to push it...
that gear set... did you make sure it was for the right series carrier? just to have those gears installed will probably be another $4-500
Old 04-26-2007, 06:49 AM
jonmark1985's Avatar
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
im sure it would help, did the lg4 have the aluminuim intake fromt he factory? i heard that one was hard to beat
Old 04-26-2007, 11:03 AM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
You're going to need a y pipe for those headers. You'd probably want to get a catback exhaust too.
Old 04-26-2007, 11:38 AM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Uhhh... I don't know of an easy way to say this, so I'll just come out & say it - I'm guessing that you'll be returning/exchanging some parts.
First off, AFAIK, the intake manifold you've chosen is a good piece, that's the best part of the group. The description for it says:
Low-end torque with improved throttle response...
...from idle to 5,500 rpm.
Which is where 95% of your driving is, so you'll like that part. (Hopefully you got the EGR version.) Unfortunately, the camshaft that you chose doesn't match the intake:
Basic Operating RPM Range: 2,000-6,000
...maximum top-end performance...
these COMP Cams Magnum series cams require a higher compression ratio, rear-end gear ratio, and stall torque converter than stock.
Now I'm just guessing here, but I suspect that these are mods you don't have yet, & if not, it might lope nicely, but it'll run like a pig. And finally.. I really hate to say this, but from the part # you provided, it appears that the headers are made to fit a full-size truck chassis...
EDIT: Forgot to mention that the 3.42 gearset is a very good choice for a street car, I'd rather have that than my 3.27s...
The key to really good performance is to have all of the parts working together, like musicians in concert. You'll be a lot happier if you choose parts with that in mind. Good luck.
Old 04-26-2007, 09:34 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
You'll be happier with an Xtreme Energy grind. Factory heads need all the help on the exhaust side they can get. A dual pattern grind will help that. Xe262 or 268 IIRC.
Old 04-27-2007, 12:38 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yea, it's not that great of an idea to do up an order, and then ask on here if it was a good idea. Not much point then eh?
MWnova66 had great success with a magnum 280 IIRC, but in a much different application. Bigger CR, long tube headers, 4.11 gears, high stall, etc.
So, like Stekman said, step down on that cam. Go dual plane. That intake manifold, you'll notice is *very similar* to your stock one. Just cleaner. But you will get a nice Edelbrock sticker. I would have went with the RPM style if I were you.
And yea, how're you going to fit up those headers?? Luckily they have a good return policy. I'd look at a header/y-pipe combo meant for a 3rd gen. Think hedmann or hooker.
Old 04-27-2007, 03:57 PM
Car: 91 RS
Engine: 350 vortec
i told you it would be faster if you got out and pushed
Vintageracer
01-10-2020 05:33 PM
beastin91rs
10-09-2015 07:38 AM
theurge
08-21-2015 12:46 PM
formula_novice
08-18-2015 08:48 PM
redmaroz
08-16-2015 11:40 PM
Quick Reply: performance guru Questions
