1986 Firebird performance
Hi I have this 86 firebird that is complete stock with 22K miles. I have had the quadrajet carb. rebuilt, and a complete tune-up and the car has weak acceleration.
I know I should keep this car original and stock, but what should I do to make the car run better? Would changing the carb. make the car loose value??
http://s193.photobucket.com/albums/z...irebird008.jpg
http://i193.photobucket.com/albums/z...irebird008.jpg
<a href="http://s193.photobucket.com/albums/z...irebird008.jpg" target="_blank"><img src="http://i193.photobucket.com/albums/z...irebird008.jpg" border="0" alt="Photobucket"></a>
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Replacing the carb with anything but another CC q-jet would not make it quicker, and very likely make it slower while reducing fuel economy and driveability, while costing more than another CC q-jet would.
Is it running worse than before the carb rebuild?
Make sure the timing is set properly. Advancing it from the factory setting often peps these cars up.
Re: 1986 Firebird performance
my mechanic set everything to original factory specs on the dyno. When you give is gas it is slow to response. I want to take it to another mechanic but I need to know what to tell them.
Engine: LS1/LQ4
The dyno doesn't help you set anything. Waste of time and money.
The timing needs to be set with the EST connector (flat 4-wire connector coming from the base of the distributor) disconnected. If you set the timing with it connected, it'll be an absolute dog.
The carb settings are all done with a dwell meter and multi-meter, or data monitor (like Auto Xray). Again, dyno doesn't help at all.
Pilotrick50
09-02-2015 12:48 PM
1986, 305, 86, aftermarket, carb, carbed, carburetor, chuckyab, firebird, performance, specifications, specs, suspension, tune, tuning, weak
