using the flex plate with a 350 engine
Car: 1986 Pontiac Firebird
Engine: 357ci 400hp 4BBL
I am swapping in a 350 engine and notcied that the 350 came with a flywheel. the 350 is from the 70's I need to use the flex plate from the 305 since I need it to bolt to the torque convertor but he 305 cranks looks circular. would it be okay to bolt a flex plate onto the 350's crank.
Car: 91 Camaro
Engine: 355 Carb
Transmission: 5 speed
Axle/Gears: 342 Posi
Re: using the flex plate with a 350 engine
The difference is between the one piece rear main seal on the 305,and the two piece on the older 350. I don't think the flywheels or starters will interchange.
I plan on using the starter from my car since it will match the flex plate. Can I just bolt it up th the two piece rear main seal crank
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You need a flexplate for a 2 piece rear main crankshaft.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Go to a parts store and ask for a 10.4" 153 tooth flexplate for a small block chevy with a 2 piece rear main seal.
can I use the one in this link:
http://store.jetracinginc.com/prc-350-153.html
mhatfield 14
10-24-2015 07:48 AM
NinjaNife
08-23-2015 11:49 AM
