Cant pump gas in
Old 07-23-2012, 06:15 PM
89IROC-Z89's Avatar
Cant pump gas in
The problem is on my 89 IROC TPI 305. I got the pump replaced a while back the first pump went out got it replaced again and when i got the car back the gas gauge did not work it reads full all the time. I let the car sit for a couple months the car ran fine and I was able to pump gas in fine. Two weeks ago it ran out of gas then I was only able to pump in three gallons now I cant even pump one gallon in, it will just spill it out after that and the gas tank is not full.
Old 07-23-2012, 08:47 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
I know you say it is not full, but it sure sounds like it. Have you tried to put a hose in the tank and try to siphon some out?
Posted from Thirdgen.org App for Android
Old 07-24-2012, 09:58 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F
Re: Cant pump gas in
(Based on empirical evidence of the tank overflowing...) Either the tank is full or you have an obstruction in there. My bet is that it's full and that your pump may have stopped working. Jump the wires to your fuel pump to see if it primes or if you can hear it fire up.
1986Z28OWNER
12-13-2015 10:19 PM
Dialed_In
08-20-2015 01:45 PM
86White_T/A305
08-17-2015 12:16 AM
355tpipickup
08-13-2015 07:35 AM
92camaroJoe
08-13-2015 06:07 AM
Quick Reply: Cant pump gas in
