Whats this plug by my ECM/UPDATED pics 8/14
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Re: Whats this plug by my ECM
more pics
Between the angle and lighting, the wire colors are not exactly clear. What colors ARE they?
Does the vehicle have a hatch release switch on the instrument panel?
Is there a factory subwoofer amp on the vehicle?
Is there a Driver Information Center (CRT?)
No Bose system
No Driver info system
2 wires are Faded pinkish with black stripe and a brown/wht stripe...Can this be the reason my fuel pump isnt priming?
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
That is called the c221 connector. It has wires for the injectors and the fan.
What? The injectors! I can't get any signal to the injectors and fuel pump to run on my restoration, can you tell me what i nee there??
See-> https://www.thirdgen.org/forums/tech...fuel-pump.html
Kinda smells like the power antenna connector to me. Check for the same wire colors in the exit point behind the passenger's kick panel.
The power antenna cables go out behind the fender there.
The connector would fit on the front side of the dash, into a relay.
You'd need to remove the plastic panel to see it.
i need a C207 female plug so i can hardwire it myself i guess
** Many thanks for the replies, as soon as i get it running bad OR good its on to Paint!
Car: 85 Iroc-Z
The female part of that plug should be under the dash somewhere on that side. Did you get the fuel pump to turn on and prime yet?
Remember, i put the TPI back on this car so i it has not run yet with it.
Please tell me that the C207 and c221 must be plugged in to run!
Car: 85 Iroc-Z
They shouldn't run without being plugged in. Here is a c207 diagram showing what wires run through it.
http://www.austinthirdgen.org/mkport..._1987_C207.gif
Thanks, By looking at the page you posted it looks as if i need the PIN-OUT for the connector for C237 Thats what my plug looks like
OK guys, i guess im going to run 12v to the pink wires and see if it will start? cant really get anywhere until i get some help or burn something up on this damn car...
Car: 85 Iroc-Z
Did you find the other half that plugs into that connector? If I remember correctly the two pink/black wires are for the injectors and the brown wire is for the fan.
Pin "A" = Injector Fuse 2
Pin "C" = Fuel Pump/Fan Fuse
Pin "D" = Injector Fuse 1
No i cant see it OR any evidence or cuts where it was... BUT however the current dash in it is cracked by the radio. I have another in the shed and i thought??? HMMMM i wonder.....does that dash have it? so i go out to look and IT DOES! But i want to wire the plug on the car now to see if the car will run.. BUT, will this plug keep the fuel pump from priming and running? If so can i run a quick run to the FUSE PNL INJ fuses right? and see if the pump primes and runs?
Car: 85 Iroc-Z
I believe it needs to be hooked up for fuel pump operation.
Re: Whats this plug by my ECM/UPDATED pics 8/14
Bump for updated pictures and the Saturday morning coffee guru's
Please, i need a definite answer
Ok i did just that.. ran tracer wires,... nothing.... Im so frustrated I CAN"T do this alone.. if theres anyone in Dallas that will help me out i would appreciate it and do pay what ever or something. I just cant do it. Its in the garage for some sort of comfort. 214.629.1802 Mike
Ok The Plug is C221 and its the dash side (black i believe) mine is not there, i see no evidence of one being there. anyway i ran tracer wires to the fuse block and got nothing so im at a loss
The middle square plug
Car: 82 Z28
Engine: 350 LT1
guy's i need help i am removing the ecm and efi from my 89 r/s to avoid problems
i am going old school which of the engine harness should i remove the one on
the right by a/c or left by brake booster
Im back, i haven't touched this since the last post, The connector IS C221, 2 pink/blk and 1 brown or tan with blk.
Here's a new question...... im using an 87 305 tpi harness in an 88 350 tpi that was converted to carb. I'm going back to the TPI. Now i've learned that the 88 has a fuse over by the battery with and orange and red wire. I don't have that anymore... Now is that because its an 87 harness?
Also i have the entire dash from the 87 because the 88 has a crack by the radio bezel but i've looked for the other side of the C221 on the 87 dash and It's there! So should i just go ahead and swap the dash (and heater core) and start all over to see if it will run or at least attempt to run? What about the Fuse that should or was by the battery? Thats weird anyway.. Thanks a million for any good advise
TTTop
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
AustinThirdgen.org has all the wiring diagrams you need. Study them to see what you have or don't have. I know it can get frustrating, but with the diagrams, you don't have to wait for someone to answer in the thread. You could even open the 87 and 88 diagrams next to each other and do a comparison to see if there are any differences. GL!
Thanks / i ordered a complete tpi book $$$.. Im going to start the dash swap first and go from there..
evilstuie
02-28-2016 03:33 PM
BurlyChev
08-22-2015 01:52 PM
1989formula5.7l
08-17-2015 02:56 PM
