What is the correct gear oil for my manual tranny
Car: 1983 Camaro Sport Coupe, T-Top
Engine: LG4 5-Liter V8, 305cid
Transmission: NWC-T5 Manual 5-speed
Axle/Gears: GU5 Axle Ratio 3.23 Rear
Hey Guys and Gals,
What should I be using in my manual transmission?
What is the correct GEAR OIL/TRANSMISSION FLUID?
Car is:
T-Top
Engine: LG4, 5-Liter V8, 305cid
Transmission: Borg-Warner Manual 5-speed
(is this transmission the non-world class (NWC) T-5?)
I called O'Reilly Auto Parts this morning and have their suggestion.
Before I post what O'Reilly's is, I'd like opinions from the "real" experts here.
Thanks!
Gene
Hey Guys and Gals,
Car is:
T-Top
Thanks!
Gene
Received 1,672 Likes
Re: What is the correct gear oil for my manual tranny
Yes that transmission is the 1st design, from before that stooooopid PIT Team Six Sigma TQM ISO 9000 buzzword got applied to the 2nd design of that product. (assuming of course that it hasn't been swapped out)
Either will work fine.
In fact, the factory waffled back and forth on that acoupla times, I guess depending on whether the gas mileage team (ATF) or the warranty team )gear lube) won th eargument that particular year, all while there were NO CHANGES WHATSOEVER to the actual PARTS.
For that matter you could probably even run em half & half if you were too timid to pick just one.
If I was still running one of those I'd use gear lube; Mobil1 75W-90.
If you'd like a laugh and a bit of confusion about the entire issue, delve into the following link:
https://www.thirdgen.org/forums/tran...ything-we.html
BTW, as most questions have been asked and answered a myriad of times, a search will more often than not dredge up the info you require.
JamesC
JamesC
"WHAT IS THE CORRECT GEAR OIL FOR MY TRANSMISSION?"
I could choose (quotes from different posts):
"most" T-5's use ATF Dextron II:
"Everything I have seen on this board says 75w-90 weight gear oil for a 83-87"
"I've even heard of people running 30 wt. motor oil in non-WC T5's non-world-class T5"
"Ford and GM say to use ATF"
"ppl told me to run gear oil like 80W90"
"This tranny did use 70W gear oil."
and the list goes on...and on.
So, If I want to flush out my transmission and fill with new fluid, what do I purchase at O'Reilly Auto Parts?
And the bottom line answer is:
Thank you!
Gene
Engine: 4++,350 & 305 CIs
I use ATF or GM Synchromesh (GM Part # 12345349).
Makes for a little better shifting box when cold and high RPM use.
In my Amazon account is my "Garage" for my '83 Camaro. I wanted to add the correct Borg-Warner Transmission I have but of the choices available, I don't know which one to choose.
My Amazon Garage
I know it's a Borg Warner 5-Speed Standard Transmission, but how do I know if it's an "MK4", "MK5" or an "MK6"?
I have no idea what those designations mean, or why they're important.
Thanks!
Gene
My Amazon Garage
Thanks!
Gene
1992 Trans Am
05-10-2023 07:19 PM
Navy8125
08-21-2015 09:32 AM
Zachattack0925
08-12-2015 09:52 PM
