Stripped Exhaust bolt thread
I was putting my headers back in and stripped a header bolt thread on the #5.
I have a heli-coil kit.
But its pretty tight to drill the hole 1st with the 25/64 drill bit.
I bought an angle drill but I'll have to cut the drill bit shorter , and even then it may not fit.
Any other pointers to do this while the heads are still on the engine and in the car?
Received 1,672 Likes
Re: Stripped Exhaust bolt thread
http://www.mcmaster.com/#standard-drill-bits/=x284tv
You're on the right track, as long as the drill you have will fit into the space at hand.
Car: 1988 Camaro
Do you have an air ratchet? They make a 3/8" drill chuck that will fit on a 3/8" ratchet drive. That would give you a much smaller right angle drill.
Air Capital Right-Angle Air Drill Kit - 3200 RPM, 3 CFM, Model# 65006 [Misc.] - Air Tool Maintenance Kits - Amazon.com
I have used this and it does the job well just expensive
Car: 1988 Camaro
I bought an off brand china one from jc whitney about 12 years ago for like 10 bucks
I got it!
I originally bought this drill
http://www.princessauto.com/en/detai...ll/A-p8571762e
But the trigger is on the wrong side!
So I bought another one with the trigger on the inside
http://www.gison.com.tw/en/product/3...GP-835ADS.html
Just barely enough room for it to drill, but I had to cut the drill bit down.
Then installed the heli-coil
Woohoo! Headers are back on
1992 Trans Am
05-10-2023 07:19 PM
evilstuie
01-09-2020 08:29 PM
