No not another cam question!
Ok so I have searched and read through tons of info on Cam's and what all the numbers mean. So based on that and what I am trying to do, plus some guidance from Comp Cams I have came up with the 08-304-8 comp cam. So I just wanted anyone's opinion that may have used or is using this cam, or just knows a thing or two about what will work. Or if you think a different cam would be better. So lets start with what I have. I have a 91Z with a 91 L98 from a corvette so it has the better heads and 10:0.1 compression from the factory. What I have done to it is ported the intake, heads and runner tubes, added headers, 3" exhaust from collector on back, and 1.5 roller rockers. Everything else is stock. All I want is for it to have a little more lope sound at idle with out turning it into a drag car. Because it is a TPI low end performance is good. Could always use better top end but I know that's always a challenge with TPI. And yes I will have a chip made for the specs.
210 \ 220 @050
500 \ 510 lift
1140lsa
1400 to 5400 rpm range
210 \ 220 @050
500 \ 510 lift
1140lsa
Re: No not another cam question!
Dont get me wrong it will work fine
I completed one car using a lt4 hotcam equivalent and it was touch lopey but the exhaust was very quiet so cam sound was masked
Got another L98 cam only deal to tune soon, after get the exhaust done. Its i believe a 218-224 110 grind i mentioned before. Seems like a great cam for it but we'll see
You can go with the cc304 cam but its pretty mild sounding on a 114 lsa
I have the 304-8 and its not bad but I would go with the 305-8 if I was doing it again.
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
Thanks.
It ran ok without any tuning but I did a mail order tune from PCMforless. But I am currently looking at switching to EBL Flash as I think it could be better.
dennisbernal91z
09-19-2016 07:00 PM
smokingss
Exterior Parts for Sale
09-08-2016 07:34 PM
ChrisFormula355
Carburetors
10-06-2000 09:08 PM
