hsr help
Old 10-10-2004, 07:14 PM
grndprixss's Avatar
Car: 85 pontiac grand prix
Engine: 355 tpi
hsr help
im almost set on getting the holly super ram i have a custom chip already made for my 355 what would happen if i run it with that chip, and the 48mm throttle body, i know i have to have the chip adjusted to the manifold but what about the throttle body will 48mm cut it or do i have to go with a 52mm,
Old 10-10-2004, 07:43 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: hsr help
That would depend. If the HSR will change the air intake at all etc. then you will need another chip. Best thing to do is buy your own chip burning stuff and do your own. I'm not saying your chip will not work but I am sure it will need tweaking to get things right. I believe holley recommends 52mm for that setup but I am running 58. Many will tell you that 48 is good enough. This has been debated too many times.
Old 10-10-2004, 07:50 PM
grndprixss's Avatar
Engine: 355 tpi
i have a 355 ive been told even by my programer (fastchip) that the 48 is good for small ci motors when u get up to 377 or 383 u need to go bigger, i put the 52mm on my car and it wouldnt run for s*it. im just trying to find out if i can run my car with it for now. and as far as a diy chip i had the accell set up and ditched it cause i could never get a chip right, i dont have a dyno and i really dont know much about it
Old 10-10-2004, 08:05 PM
Neither do I but I bought the stuff anyway. Got a cheap laptop with an aldl cable and craigs moates stuff and I am in the process of learning it. The car probably ran like crap when you put on the 52 because of what I said earlier. There is now more air coming into the motor. That means it is affecting the set perameters on the custom chip. Once you start changing things after you get a custom chip you have to re-do it again in most cases. Do some datalogging. Read my horror thread on why you shouldn't tune a car through the mail. Here's the thread...
https://www.thirdgen.org/techbb2/sho...chips+yourself
Old 10-10-2004, 08:09 PM
As I have said already...this has been debated way too much. Several people will tell you that 48mm is good for high hp engines and others will say no. Put it on and try it.
Old 10-10-2004, 08:14 PM
grndprixss's Avatar
Engine: 355 tpi
thanks for the link to the post capt i feel inspired, do u just drive the car around to tune or do u put it on a dyno
Old 10-10-2004, 09:06 PM
You can tune in the driveway, or on the fly with Craig's autoprom.
Old 10-11-2004, 06:49 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
If you think that is hard, come and see what I can do with a little Mega Squirt.
squirt, squirt, squirt
Old 10-11-2004, 06:53 PM
grndprixss's Avatar
Engine: 355 tpi
im sure the mega squirt is great im pretty good with the painless set up i am just really pissed at the chip i cant hit over 3000 with out the thing pinging to hell cause the dam programer would believe me when i told him i had 10.5 compresion
Old 10-11-2004, 06:59 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Old 10-11-2004, 07:20 PM
grndprixss's Avatar
Engine: 355 tpi
too much spark advance almost 48 degrees
Old 10-12-2004, 08:39 AM
Tibo's Avatar
Car: 1991 Z28 Vert
No I see. right now Mega Squirt only controls my fuel, so I am using Mechanical advance until Ultra Mega Squirt comes out. I only have about 34 degrees total timing at the moment.
Old 10-13-2004, 06:54 PM
grndprixss's Avatar
Engine: 355 tpi
the squirt system sounds great but i wanna work with what i got the factory type system i mean i got some cash in it and as of now its pretty good, i got to get something done about my timeing it pisses me off when a ***** blows by me and i cant go bast 3000 cause of fear ping, i mean i got over 400hp and i cant use it dam tuneing by mail
86z89iroc
10-05-2015 01:04 PM
86CamaroDan
09-29-2015 10:08 PM
mike22115
09-28-2015 04:49 AM
BBSDesigns
09-22-2015 03:08 PM
355tpipickup
09-04-2015 05:32 PM
Quick Reply: hsr help
