How do you bypass the heater core?
Car: 89 formula, 90 vette, 00 05 stang
Hello All, I have recently obtained a 1989 GTA with a 350 and tpis mini ram intake manifold. My question is How do you bypass the Heater Core/Hoses. There is a fitting in front of the TPIS intake manifold, can i plug this ?
Re: How do you bypass the heater core?
Unless you are completely going to remove the entire HVAC box and blower assembly its not worth it at all to remove it. Gains you nothing.
Follow the heater core lines to the water pump assembly.
I dont have any heater lines. Only hose i have is the upper and lower rad hose. I need to figure out what to do about the coolant fitting in front of the TPIS intake manifold.
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Yes, you can remove that fitting and put in a plug. (A pre-vortec SBC has an internal water bypass, so coolant will still circulate before the thermostat opens.)
Or... you can get a length of heater hose, and connect that fitting to the return fitting on the radiator.
Thanks MoJoe, Thats the answer I was looking for. I already replaced the fitting with a pipe plug.
BrianI
11-08-2015 07:04 PM
