700R4 shifting question
Old 07-13-2007, 11:59 AM
novatuc's Avatar
Car: 1984 Trans Am
While just cruising at light load, my 700R4 only shifts into 4th gear above 45 mph. If I drop below 45 mph it shifts back into 3rd. The tranny all seems to work fine, no hard shifts, no weird noises so I'm not sure if I have a problem. Is that how they work or do I need an adjustment somewhere? The car has a 2.92 rear. Perhaps it is shifting based on rpm. Any thoughts?
Old 07-13-2007, 04:08 PM
performabuilt's Avatar
Re: 700R4 shifting question
From the sound of it and with that high gear seems normal all good to me
Old 07-14-2007, 04:07 AM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
I have 2.73 gears and when i hit 42 or so it will shift into overdrive, wont go into overdrive lower than that. When i go lower than 40 it goes back into 3rd, i think it has to do with the governor. Sounds normal to me too.
Old 07-14-2007, 05:32 AM
ranone21's Avatar
Car: 1989 Trans Am t-top WS6
Engine: 305 tpi
It does sound nornmal... I have had 2 of the overdrive gm trannys and they seem to only shift into overdrive (4th gear) at around 40-45 mph.
Old 07-14-2007, 06:40 AM
novatuc's Avatar
Car: 1984 Trans Am
Thanks guys, that's what I wanted to hear. My daily car is a Malibu Maxx with the auto 4 speed. It gets into 4th as soon as it can and stays as long as it can. So I was just curious.
Old 07-15-2007, 03:06 AM
camaro1992's Avatar
Car: 92 RS Camaro
Engine: V8 5.0 TBI
What about when it goes back into third, and tries going back into od? Any hardness or hesitation? Do you have this?
Old 07-15-2007, 07:45 PM
novatuc's Avatar
Car: 1984 Trans Am
camaro1992
Nope, everything is smooth. The only thing I actually notice is the revs of the engine going up and down with the gear changes.
Old 07-16-2007, 01:12 PM
Shagwell's Avatar
Car: projects.......
that sums it up......it doesn't need OD at lower speeds with a gear that steep.
jklein337
09-19-2018 06:23 PM
camaro11j
09-19-2018 08:49 AM
g.l.mos
08-22-2015 12:02 AM
redmaroz
08-16-2015 11:40 PM
TreDeClaw
08-14-2015 06:58 PM
Quick Reply: 700R4 shifting question
