Installation of a drain-plug kit.
Old 11-07-2008, 12:27 PM
NoTransistors's Avatar
Car: '83 Firebird S/E
Engine: The Chevy 305. with carburator
Transmission: 700R-4
I picked up a drain plug kit marketed by B&M.
Whether I change the fluid/filter now or in the spring, the following questions will weigh on my mind until then.
The kit comes with a plastic washer to seal against the pan. Does it sound like a decent idea to replace it with a copper sealing washer?
And, do you knowledgeable mechanics have a favorite place to locate the assembly, that is far away from any and all things inside?
Seth
Old 11-07-2008, 01:57 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Installation of a drain-plug kit.
A plastic washer will seal better than a copper washer.
Better than one of those kits is to tack a weld nut on the inside of the pan and use a drain plug.
fasteddi
09-02-2015 10:29 AM
g.l.mos
08-22-2015 12:02 AM
crazynights
08-21-2015 06:53 AM
rsrmoore
08-07-2015 08:44 PM
drathaar907
08-06-2015 04:20 PM
Quick Reply: Installation of a drain-plug kit.
