4th gen rear swap today :)
Old 08-02-2015, 02:53 PM
Amillionoh7's Avatar
Car: 92 RS
Engine: Sbc With h/c/i/e holly4150
Transmission: 700r
Picked up a 96 z28 rear end yesterday. Rpo g80 / gu2
So 2.73 gears and an Auburn LDS
Got to work first thing in the morning and had it in before lunch.
Now just need some better rims
Size:  326.2 KBName:  20150802_141901_zpsmiproxtn.jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old 08-02-2015, 02:55 PM
Car: 92 RS
Transmission: 700r
Re: 4th gen rear swap today :)
sorry for messed up pics. probably shouldn't has started to drink till afterward
Old 08-04-2015, 07:06 AM
UltRoadWarrior9's Avatar
Car: 1986 IROC Z-28
Engine: 383 Gen I SBC 11:1
Transmission: Rebuilt TH700R4 for 500+HP
Axle/Gears: 4th Gen 10 bolt Eaton Truetrac 3.23
Nice! I remember how excited I was when I put a 2002 Z28 axle with 3.23 gears. It too had Auburn LSD. I'm upgrading the Auburn LSD to a Eaton TrueTrac. Also, I'm thinking of going up to 3.73 gears. You might want to lose that Auburn unit too, or maybe burn it out first? Lots of info on TGO about how the Auburn unit is not rebuildable.
Your tires sticking out about another 5/8"???
Old 08-04-2015, 08:06 AM
Car: 92 RS
Transmission: 700r
Will swap the auburn when it finally gives out but is holding strong for now. and my tires stick out crazy far now. I picked up some z06 rims but they need tires yet. when I get some tires on there I will post a pic
Old 08-05-2015, 04:49 PM
Car: 92 RS
Transmission: 700r
Old 08-06-2015, 08:00 AM
Car: 92 RS
Transmission: 700r
Old 08-06-2015, 11:43 AM
Car: 92 RS
Transmission: 700r
Old 08-06-2015, 02:18 PM
Car: 92 RS
Transmission: 700r
Old 08-06-2015, 04:24 PM
keykey's Avatar
Car: 1988 Trans Am GTA
Engine: 350 TPI (L98)
Transmission: TH700R4
Axle/Gears: 3.27 9-bolt w/ Torsen LSD
Love those burnout tracks! Great job with the swap!
Old 08-06-2015, 05:02 PM
Car: 92 RS
Transmission: 700r
Thanks! I wasn't sure if it would spin those big nitto's. I happy wit how it turned out and would recommend the swap.
Old 10-04-2015, 03:08 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
How much room between the fender lip and the tire do you have now
Old 10-05-2015, 07:42 AM
Car: 92 RS
Transmission: 700r
Im still on stock springs so about 3"
Old 10-05-2015, 09:23 AM
morrow's Avatar
Car: 92 Camaro Rs.R
I mean side wall to inside of the fender lip
Old 10-05-2015, 12:19 PM
Car: 92 RS
Transmission: 700r
Oh if it was lowered im sure it would hit. It looks about flush with tire.
Old 02-21-2016, 09:30 AM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Looks nice
Old 03-01-2016, 06:57 PM
729rs's Avatar
Originally Posted by IROCgiraffe
Looks nice
Hey did you use the stock lca or adjustables? Did you have to aling it after the swap? I just did a similar swap but my right wheel is toe in I don't know why
Old 03-01-2016, 07:05 PM
Car: 1986 IROC Z-28
Try adjustable panhard bar before adjustable LCA's... I remember similar issues after my 4th gen diff swap. It's trial and error to get the centering right depending on tire sizes, suspension parts, bushing type, etc.
I remember trying to space the tires to the body equally while adjusting the panhard bar, and it was still off center. Good luck.
Old 03-02-2016, 07:46 AM
Car: 92 RS
Transmission: 700r
I used the lca n ph bar from the 4th gen. and I did do an alignment but that's what I do for my job so was no biggie.
Old 03-02-2016, 09:17 AM
729rs's Avatar
The 4th gen car I took it out of was wrecked from that side I'm now thinking that the diferential might be bent cuz I measure both sides of the wheels and it's about 5\8 difference
Old 03-02-2016, 09:18 AM
Car: 92 RS
Transmission: 700r
sin the wheel and see if it change. the axle shaft may only be bent not the entire housing.
Frozer!!!
01-19-2024 04:55 PM
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
mizz0313
08-12-2015 06:45 AM
THABADGUY
Brakes
08-11-2015 03:43 AM
Quick Reply: 4th gen rear swap today :)
