rear axle from corvette
Car: 1984 camaro
Engine: 305 v8
Transmission: auto 4 speed
ok so my transmission is going out and my father in law has an 84 vette im going to take the trans from it because its the same 700r4, but my question is will it be hard to take the rear axle from it too and put it on my 84 camaro, because mine is the old drum and i know the vette is pads
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: rear axle from corvette
You are comparing an independent rear to a solid axle. Go look under the vette and then under your car and you will see.
1 Post
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Car: 1984 camaro
Engine: 305 v8
ok thanks, another question could i replace my differential with the posi out of the vetter
Engine: 355 TPI
No. Nothing interchanges between the vette rear and yours.
Yukon makes a Dura Grip that will fit in your Camaro rear end. It's the cheapest but good quality differential for the 7.5 10 bolt. You must know what your gear ratio is before you buy one.
1988_f-bird
03-15-2016 01:06 AM
vortech305
Aftermarket Product Review
02-08-2001 08:56 PM
