700r4 to 4.3 truck t-5. Have few questions...
I have a firebird with a 350 tbi. I know the bellhousings are the same for the 4.3 and 350s. But I heard you have to change the tailshaft housing as the third gens have a slight angle. Is the transmission itself a direct bolt in or do I have to change the tailshaft housing for that angle. And do 4.3 trannys have 10 or 27 spline shafts?
Car: '02 T/A
Transmission: 4l60e
Re: 700r4 to 4.3 truck t-5. Have few questions...
Oh ok so do you think the nv trannys would work? If not then will a mustang t5 work? I know I'll still need the output shaft housing but do I need to change the input shaft?
Car: '02 T/A
Transmission: 4l60e
Are you just trying to do a 5 speed swap? Im selling all of my 5 speed parts including both t5s.
Yea. But not trying to spend over 200. There's one off of a 3.4 on craigslist for 75. Just need the belhousing for v8. But of course no phone number just email. So I gotta wait for a reply
Car: '02 T/A
Transmission: 4l60e
V6 from a 4th gen uses the ford pattern so it won't mount to a sbc. Considering all the parts needed you're not doing the whole swap for $200.
Yea. I don't wanna pay over 200 for the transmission. I'm getting the master and slave new. And pedal assembly online i can't find one locally. And then the console cover. And crossmember.
1 Post
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
They're out there, but you gotta spend some time looking. I wouldn't mess around with trying to make one fit, find someone parting out their car and just ask for everything you need. It took me awhile to find exactly what I wanted, but I got the whole setup for 500. Pedals, trans, cross member, shifter, master/slave. Bought a new clutch/ pressure plate from rock auto. Just gotta hunt down a manual shifter plate for a firebird, found out the hard way a camaro shifter plate won't fit a firebird lol
Where to start...
Torque Arms, thirdgens have em. They bolt to the tailshaft of the transmission. Aside from some 4th gens, any transmission that didnt' come from a thirdgen isn't going to support the torque arm mount. You can relocate the torque arm mount, or go to an aftermarket torque arm, but that'll consume most of your $200 budget.
Shifter location. The T5 from anything but a thirdgen is going to have the shifter in the wrong place.
Bellhousings... Any SBC pattern bellhousing will bolt to a SBC, but thirdgen T5 bellhousings have the transmission mounted at an angle.
$200 might buy a junkyard transmission that may or may not work. But thirdgen V8 T5s are hard enough to find that you probably won't find one.
1 Post
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
$200 T5 is a pipe dream. Let's break it down.
$200 T5, that is more than likely broken (or it wouldn't be $200)
Rebuild kit, that'll cost ya a couple hundered more
Harbor Freight Press $200
Output shaft (if you can find one on ebay) $100
Now your $200 T5 has cost you $700 and hours of labor & its still not in the car.
