installing the plenum
Old 10-10-2012, 06:41 PM
Ratchet23's Avatar
Car: 1991 firebird
Engine: 5.7 v8
Transmission: manual
Hi i comp tested all te cylinders hand 5 were 135-160 and 1 was 0 so i adjusted the rockers and now i go to re install the plenum and i cant figure out where all the bolts go. Does anyone have instructions or a bolt pattern. To do so thanks in advance"
Old 10-10-2012, 06:51 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: installing the plenum
Wait a second.... you tested all the cylinders and 5 of them were between 135-160psi? And the last one was at 0???
Old 10-10-2012, 06:56 PM
Ratchet23's Avatar
Car: 1991 firebird
Engine: 5.7 v8
Yes and i adjusted the rocker arms and it tested 145 after that but cant figure out the plenum
Old 10-10-2012, 08:23 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Im just lost on how adjusting your rocker arms got you from 0 to 140 or whatever psi on a comp check. Thats acting like you valve/s on that cylinder was never closing at all under compression. If the rocker/s were that tight, im amazed that you didnt bend a push rod. And whoever tightened them down over did it soo soo much!! Never heard of that one.
But really the bolts are easy to put back on, no guide but theres about 10 IIRC on the lower then the mid has about the same and the upper has 10 bolts. All 10mm and 13mm ones. Be sure to use the ones that have the washer build on them on the lower intake to the head. Basically just put the bolts into the holes with threads below??? Best way I can explain it. But just be carful to not over tq the bolts or cross thread them as for the most part your bolting into alluminum which those steel bolts will eat up if there not in there right.
Best of luck and mabey someone will chim in with a better explanation.
Old 12-07-2012, 02:38 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
sounds like he didnt rotate the crank and a valve was left open durring this test
Old 12-07-2012, 10:08 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Our engines are NON-interference... Except in the cases of the newer 3x00 where the piston actually comes OUT of the block.
The longest bolts go in the lower plenum. There will be 2 medium length ones for the fuel rail (the bolt hole towards the outer edge of the lower plenum goes on the RIGHT and the 2 for the fuel rail on the LEFT), 2 more medium ones for the EGR transfer tube, 2 short ones for the throttle/cruise/TV cable bracket, and the remaining 10 with 10mm heads (actually, 8, the other 2 are studs for the A/C compressor upper bracket if equipped and go in the 2 holes on the front right corner) are for the upper plenum. The 2 bolts with 13mm heads are for the throttle body. They ALL get torqued to about 12-15 pounds. And make sure you get the valve covers tight... The torque spec on those is complete BS.
Old 12-15-2012, 06:38 PM
jackhammer's Avatar
Car: 1987 Camaro RS
Engine: V6
Transmission: Automatic
I just read this and I thought someone might know; I am about to remove my plenum to fix the fuel pressure regulator. Is that a gasket I see? Do I need to replace it?
Old 12-15-2012, 06:49 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Yes it is. Replace any gaskets you removed.
Old 12-15-2012, 08:05 PM
jackhammer's Avatar
Car: 1987 Camaro RS
Engine: V6
Good to know. Thanks for the quick reply.
redmaroz
04-25-2017 07:14 AM
MantyZ28
16
12-21-2015 11:02 AM
Hawkeye1980
08-31-2015 07:09 AM
ASE doc
Alternative Port EFI Intakes
08-25-2015 09:14 AM
355tpipickup
08-22-2015 06:06 PM
Quick Reply: installing the plenum
