Widest tire on 91-92 z28 wheels
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Hi I am wanting to know the widest tire I can put in my car I have the 16in wheels and would really like if it's possible to put 275 on them I just live the look of wide tires.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Widest tire on 91-92 z28 wheels
without changing the overall height of the tire, you are limited to about a 245 or 255 tire.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
What if I change the overall tire you think I would be able to get 275's on heir or is that too wide.
have seen 295's on the stock wheels, but they are getting pretty tall at that point. Just check the tires manufactures recommended specs and see what the recommended minimum/max rim width is.
Car: 87 GTA
Whoa....You can't judge a tire simply by its width.
I've run the BFG 295/50R16 on stock wheels on my 1992 RS.
Stock 245/50s - 25.7"
BFGs 295/50s - 27.6"
Yes.....Almost a 2" difference overall, but my speedo wasn't off enough to cause me to go get the speedo gears in tranny changed out. Sorry, these are the only pics I have that kinda show it.
Car: 91 RS vert/ 89 iroc vert
Engine: 305 TBI/305 TPI
Transmission: 700r4Xtwo
Axle/Gears: 10 bolt non-pos. B/W 9 bolt pos
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Those tires did not rub when you took turn and also around how many inches wide are the 295. Also around how much did each of your tires go around for.
Car: 87 GTA
Look at the Tirerack link I provided & it'll give you the width & all the other specs you might want on them.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Thank you all very much i am gonna be running these setup until i have for some nice wheels. By the way does anyone one know what kind of wheels these are the ones on the camaro i love how those wheels look.
https://www.thirdgen.org/forums/albu...pictureid=2902
1992rs/ss
16
01-28-2016 09:58 PM
