Correct sizes for 19 wheels
Old 06-07-2016, 11:23 PM
gpetry's Avatar
Car: 1989 IROC-Z
Engine: 5.7
Transmission: T56 6 Spd
Axle/Gears: 9 Bolt 3.70
I have searched everywhere I know, and this seems to be the consensus, but I just wanted to make sure before I order that I am right on these rims.Going to order a set of Intro V-Rods for my 89. Car is slightly lowered on hotchkis springs. LS1 front brakes and stock PBR discs in the rear. Planning on the following:
Rear Rim 19x10 w 6.25 backspacing and 285/35/19 tire
Front Rim 19x8 w 4.25 backspacing and 245/35/19 tire
No spacers front or rear. Any potential problems with clearance that I can't foresee? Car is at body shop right now so I don't have a way to get exact measurements off of the car and Intro is 8-10 weeks out so I want to get ordered now rather than waiting if possible.'
Thanks!!
Old 06-08-2016, 06:56 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Re: Correct sizes for 19 wheels
Should be ok
Rear wheel well may need alittle hammering in the front corner. May rub there with those tires
Old 06-08-2016, 10:09 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
I would suggest you upgrade the fronts to the same size as the rears.
This will give the car better handling balance (more neutral vs. understeer) and also increase handling and braking capability.
Old 06-08-2016, 10:12 AM
gpetry's Avatar
Car: 1989 IROC-Z
Engine: 5.7
will that size wheel/tire/backspace combo clear in the front and still have a nice tuck on the wheel wells?
Old 06-08-2016, 10:16 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I would just be worried about clearance with a 285 up front. Its already tight with a 255 lock to lock on a lowered car
I run 18x8.5 and 19x10 staggered and never had a complaint on handling and stopping power, and i shut down from 170 mph at the strip with a short shutdown and no parachute with a c5 front brake and ls1 rear
Old 06-08-2016, 03:23 PM
carlos64030's Avatar
Car: 1991 Trans Am GTA
Go with 275-30-19 tires on all four corners and you won't have to make any modifications. A 275-30-19 tire is the same overall diameter as the stock 245-50-16 tire these cars came equipped with. For a visual reference, the front wheels and tires on my WS6 Trans Am are 19 x 9.5 with 275-30-19 tires.
Old 06-08-2016, 04:08 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I believe 4th gens had more room up front. I had one and easily fit 275 tires as thats what they came stock with
The diameter isnt an issue, its width and i was thinking a much wider than 245-255 front may reduce lock to lock range on steering
I havent tried wide fronts on a thirdgen. But i know guys have run 17x9 275 tire all around before
Old 06-08-2016, 04:27 PM
A 275 tire fits perfectly on 3rd gens. I have 275-40-17 tires on 17 x 9 wheels on my GTA. Both of my cars are lowered, btw.
Old 06-08-2016, 07:40 PM
paul_huryk's Avatar
Pretty much anything wider than 245 rubs up under full lock - but won't rub driving with up to a 295 up front - assuming the right wheel specs are used.
Keep in mind that over 70% of braking force is generated by the front wheels and tires - the wider the tires, the more grip - the more grip, the better braking will be under all dry conditions.
Old 06-09-2016, 05:20 PM
gpetry's Avatar
Car: 1989 IROC-Z
Engine: 5.7
Thanks everyone - I have ordered the wheels in the sizes I proposed. I understand the compromises of doing different sizes front and rear, but felt like the tradeoff was worth it. We will see how it works when they get here in 8-10 weeks
Old 07-26-2016, 03:34 AM
M3638's Avatar
Car: 1990 Iroc Convertible
Here are the tire size that you are talking about with 19x8.5 fronts w/a 1" spacer and 4.75 back spacing. I put the 1" spacer in there in order to be able to put on the center caps, without them the caps wouldn't go on. Rears are 19x10.5 with 6.23 rear spacing and a very thin "stock spacer". I had to "massage" the inner rear fender for the wheels in order for them not to hit the inside, not much. No hitting in the front or rear with this set up.
Attached Thumbnails Correct sizes for 19 wheels-chromeoz5.jpg   Correct sizes for 19 wheels-chromeoz8.jpg   Correct sizes for 19 wheels-chromeoz13.jpg
Old 07-26-2016, 06:13 AM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
A 245/50R16 is 25.7", a 275/30R19 is only just 25.5", and a 285/30 on a 10 is a better match for a 245/35 on an 8.
Others have tucked 285s on 10.5s, front and rear, with room to spare, so IDK why you'd run 8s up front, unless you don't enjoy cornering.
88 vert guy
Brakes
07-14-2017 09:13 PM
BG1959
07-20-2016 02:22 PM
apie2546
Wheels and Tires
03-30-2016 08:12 AM
Procharged GTA
Exterior Parts Wanted
03-26-2016 01:56 PM
NHL69
Exterior Parts for Sale
17
03-17-2016 09:36 PM
Quick Reply: Correct sizes for 19 wheels
