gas milage on a 305 tbi
Car: 91 formula
Transmission: t5
what is everyone else getting for gas milage from their 305 tbi's ? i know mine is horrible it is like 10 miles to the gallon
i am getting like 150 miles to a tank and the tanks are 15 gallons right ?
Am getting around 350 km per tank, converts to a little more than 200 miles, mainly city drivimg in MOntreal, Canada . On highway, more economical because of 70 mph @ 1600 rpm...good luck, mine's an autom = TH700r4 ??
'88 Camaro coupe 305 TBI
46 000 miles
46 000 miles
Engine: LO3;383tpi
10 mpg is horrible. If it is completely stock, you should be getting 20+ on the highway. Is your computer putting out any codes? they will drastically decrease milage depending on the code
Car: 91 formula
Transmission: t5
i have no idea if it is putting out codes, the lady i bought it from said it had a chip in it, but she had no idea what kind or anything about it, where is it and i can look to find out what it is and maybe someone can help me from there, but i was hoping that it was maybe just me and not all firebirds/camaro's cuz that would be just horrible for all of them to have that bad of milage, atleast now i know i can have it looked at and figure out why it is getting such horrible milage
Car: 1991 RS
Transmission: auto
I just put about 355 miles on my last tank, so I'm thinkin that has me around 23-25 mpg. It's all stock except for the open element.
Scoty
Scoty
In the city I get between 16-18 mpg and on the highway I will usually get over 25 mpg, but I've never really driven a full tank on the highway so it's not 100% accurate.
Car: 92 Camaro RS
Lot of badly tuned TBI Camaros out there I guess, I have NEVER gotten less than 20MPG avg. from a tank, and can get 27-31MPG on the hwy. That's 400-450 hwy. miles on a tank folks!!!
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
Same as above here. 305TBI auto w/2.73's(other mods listed in sig) and I got a little over 650kms(140km/hr avg speed) on a highway trip up north this summer. I'll get at least 400kms in the city but not more than 450kms. 213,000kms on the motor. I d
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Before I modded it, all stock except for open element I knocked off a couple of 31mpg trips. Now it is much much worse
Car: 91 formula
Transmission: t5
would the straight exhaust have anything to do with it, if i put a muffler on it would it help it at all, creating more back pressure ?
NO, Backpressure is bad in just about every way you look at it, including power and effeciency.
Car: 97 Z71
Engine: 350 Vortec
Jared
Car: '91 RS
Engine: LO3, For now...
With stock exhaust: 20 mpg everyday driving, 27-28 mpg highway
With headers and catback: 20 mpg and 28-30 mpg
Backpressure - BAD....... Free flowing exhaust - GOOD
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
with my setup i avarage around 25-26 mpg with mixed highway and city driving, assuming i dont beat on it. Liberal use of the go pedal results in the car emptying the tank in no time flat.
Car: '91 RS
am i correct that there is a 15 gallon tank under there ?
Car: 1990 Camaro RS
i get about 18-22 city driving, and about 32-34 on the hi-way.
lots of chip tuning ot get there running 6* timing, i have hi-way mode set to about 17.8:1AFR.
btw, that is with a 3.42 rear gearing, and a T5.
Car: 1990 Camaro RS
its just one more reason for people to get into chip tuning, driving for a year, the gas savings alone would pay for all of the equipment. heck for the guy getting 10mph, the 22mpg savings would ad up FAST.
Car: 91 RS
Engine: LO3
it would add up fast. i wish i could get into chip burning, but i believe im far too computer illiterate to be any good at it. oh well, just have to have someone do it for me.
Car: 1990 Camaro RS
it really doesn't take any computer skills. it is all math. if your BLM's are off by 4%, you change the fuel by 4%, ect. nothing that takes a CS degree.
Car: 1992 camaro rs 97 yoyota camry
Engine: lo3 carbed
Transmission: t 5
i got 24.8 mpg going to ga doing about 80-90!!! i am also burnin oil like a mad man!!! but i have 138,000 miles on the car i think i should have spent a little more time and chaged the valve seals when i did the cam. but this is a 305 lo3 when the engine goes i will be puttin in a 350!!
Car: 1990 Camaro RS
all the BLM, INT, PW, ect, will make sense to you. read the articles about tuning for newbies on the diy board, they go step by step on what to do, and explain what all of those mean.
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
I need to read up on tuning too, dont know **** about it.
Anyway, i get about 17mpg (if im nice )15-16 if im not, but im getting an error 32 code right now. Does anyone think fixing the EGR valve would help my gas milage out? Ill be getting new plugs at the end of this season too, that should help also.
Car: 91 RS
Engine: LO3
try soaking your egr in carb cleaner, worked for me. probably would help your mileage. but i wouldnt advise letting it get to the diaphram though. just the bottom half.
Car: '90 Camaro RS T-Top
Engine: 5.0 TBI
Transmission: TH700R4
Some of you guys make me envious, I get like 13 city, 16 hwy, with an L03/700R4/2.73:1 gears. I keep it in tune...
Keep in mind all these #'s mean nothing. 90% of it is all in how you drive it. If you go around flooring it everywhere ofcource your gas mileage will suck. If you don't drive like an idiot most likely you will get pretty good mileage.
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
Well with no fuel gauge I actually had to keep note of my gas mileage. I usually filled up every 150 miles and it put about 9-qo gallons in the tank. Then I got my straight pipes put on and, well I kinda like the sound so I get anywhere from 9-15 mpg But over all I would get 20 highway, 15 city.
Lc
Lc
Car: 89 Formula
Transmission: TH 700R4
46 000 miles
46 000 miles
Don't trust the gas guage---real, real, pesimistic
True '87 1LE
No, more economical on highway, over 400 km I guess. I live in Montreal so , mainly city driving. Changed fuel filter recently, noticeable difference overall, thus probably more economical now. Pretty well tuned up . Will keep count and reply soon... : ) Have to do O2 sensor soon...mine's pretty much stock but slowly improving it...BTW, you have a true 1LE? Excuse me for asking, please some pics : )
Thanks Hoser....from a Frenchie ! (he he)
well...
I live in the city. I mainly speed everywhere i go and take as fast as well. I am the one that posted about the no thermostat. some guy,i think it was nick harmon, asked me how many MPG i get. well. i decided to give it a try..i put in 7.2 gallons....and i got 140 miles. It is atleast 20 miles per gallon.
I have no thermostat so thats a free flow, and my fan is installed straight into the ignition key. I think its pretty mpg for the way i have my car.
Engine: LO3;383tpi
engine temperature
My engine runs between 160-220 during the severly hot days. if i Accelerate peeling out often then the temp will run up to 220...during the night crusing it says around 160....
