{SC} FS: Earl's braided rear brake lines, chassis to axle with "T" block
Old 05-03-2007, 02:27 PM
ebmiller88's Avatar
Earl's braided center chassis to axle brake lines. I have 8 of these lines available. This line connects the chassis brake line to the axle hard lines. New lines that have the "T" block in them.
$25 shipped to you.
Ed
Old 05-03-2007, 05:48 PM
84TranzAm's Avatar
Car: 84 TA Black/ Gold
Engine: 383 With Vortec Heads
Transmission: 700 R4 Lvl2 Performabuilt 9.5 Vert
Axle/Gears: Moser 9" with 3.70
Re: {SC} FS: Earl's braided rear brake lines, chassis to axle with "T" block
Will these blocks work with 93-97 hard lines? Or are they just for 82-92. Thanks
Old 05-04-2007, 09:45 PM
ebmiller88's Avatar
They will work, and they're part of the 3 pc. rear set.
Ed
Old 05-08-2007, 06:50 AM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
Ed,
Can you post a pic?
Old 09-27-2007, 08:06 PM
ebmiller88's Avatar
I still have LOTS of these available, come get 'em. I'll have to track down a pic.
Ed
Old 01-17-2009, 01:13 PM
ebmiller88's Avatar
I have about 15 of these lines now, price reduced to $20 shipped for the braided T block line (cont. US only)
Ed
Old 01-17-2009, 03:21 PM
SLP-GTA's Avatar
Car: 1991 Formula (sold)
Ed
I'll take one, IM me you PP addy..
Also, I really need to talk to you about a front package for my 91 Formula.
I want to keep my stock formula 16inch wheels. Im leaning toward the 13inch with wilwood cailpers. My question, will I still be able to use my stock lugs nuts and plastic GM cap covers with the arp studs??
Also my new personal plates are FLYNBYE do I get a discount for advertising your performance shop
Old 01-17-2009, 07:37 PM
dv8
dv8's Avatar
Car: 88 IrocZ Vert
Engine: 5.0 TPI
how long is the line?? from fitting to fitting... I'm looking to use it in a more custom application.
Old 01-18-2009, 01:12 AM
lt1ironhead's Avatar
Car: 83 Trans Am
I'll take one . Pm on how to pay you.
Steve
Old 01-18-2009, 10:01 AM
ebmiller88's Avatar
I'll PM those with the needed info and post a pic later tonight. Thanks!
Ed
Old 01-18-2009, 11:43 PM
89406Iroc's Avatar
If you still have some available I want one. Thanks
Old 01-19-2009, 10:29 AM
ebmiller88's Avatar
I have plenty and here's a pic of the line:
This line will work on all 3rd gens regardless of rear disc or drum, and therefore also works with LT1 and LS1 brake conversions assuming you will use 3rd gen axle lines.
I'll PM those interested today. Thanks!
Ed
Old 01-19-2009, 03:02 PM
Doc_G's Avatar
Car: 87 Trans Am
Axle/Gears: Not enough
ed is that price 20 shipped per or a pair?
Old 01-19-2009, 10:31 PM
ebmiller88's Avatar
One single line, the one that goes from the chassis to the rearend. It'll work on disc or drum cars.
Ed
Old 01-19-2009, 11:03 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Ill take one!!
Old 01-20-2009, 10:04 AM
mark4iroc's Avatar
Car: 88 iroc
Engine: 355 tpi
Axle/Gears: 3.27 borg warner
Ed,
I'll take 3 of them. PM me about some brakes!
Thanks,
Mark
Old 01-22-2009, 07:30 PM
dv8
dv8's Avatar
Car: 88 IrocZ Vert
Engine: 5.0 TPI
I'd still like to know how long they are??
Old 01-22-2009, 10:00 PM
SLP-GTA's Avatar
anyone one else get a PM??? I have not??
still needing a PP addy to pay
Old 01-23-2009, 09:55 AM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
pm sent. iwant one
Old 01-23-2009, 10:21 AM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
pm sent--I want a set
Old 01-24-2009, 08:30 AM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
will they fit if i have a fourth gen rear?
Old 01-26-2009, 07:41 PM
ebmiller88's Avatar
4th gen rear if it's a LT1 rear ('93-97) or you use 3rd gen hard lines on a '98-up LS1 rear, yes. Stock 4th gen LS1 rears use flare fittings on the interior line joints and bubble flares on the caliper ends, these lines have bubble flares on the outlet ports.
EDIT: PMs sent to all, sorry for being late fellas.
Ed
Old 01-26-2009, 08:13 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I'll take one.
PM sent.
Thanks Ed
Old 01-27-2009, 10:07 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
I'll take one too Ed. Wish I knew about these when I bought the C4 swap from you. I'll send payment out in a couple day.
Old 02-06-2009, 01:41 PM
ebmiller88's Avatar
Hi Will, sent you a PM and e-mail as I'm ready to ship your C4 stuff (finally!)
I'll throw the rear line in as well
For others interested, I have 4 lines left at this price.
Ed
Old 02-06-2009, 03:49 PM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
Hey Ed, I'll take one!
Old 02-07-2009, 02:54 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Ed, any idea when these will ship?
Old 02-07-2009, 05:28 PM
livewire's Avatar
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
My car is a 83 doesn't it use SAE fittings back there? if it will work on my 83 I'll take one as well. I've got a 2000 Rear so i'll have to change the axle hard lines regardless.
Old 02-08-2009, 07:38 PM
ebmiller88's Avatar
Hi fellas, I just found a short stack of boxes with lines that have not shipped so that's the delay in a few orders (chevymec), my fault and I apologize. I'll be sending them out tomorrow via Priority Mail.
'82-83 are the crossover years, I can't verify if the line will fit but if it won't you can return it and I'll refund your payment, LMK.
Ed
Old 02-08-2009, 09:10 PM
ebmiller88's Avatar
OK, I just got the following guys taken care of:
Ken T, Mark G, John M, Jim N, Alex O
LMK if I missed you or you would like one, I have 2 or 3 left.
Thanks all!
Ed
Old 02-10-2009, 05:37 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
Thanks all!
Ed
Hi Ed do you still have any of these left? I am looking for a set for my '90 IROC. Can you PM me your paypal address and I will send the $$$
thx
Old 02-10-2009, 09:55 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Got mine today!! Thanks Ed.
Old 02-11-2009, 08:48 AM
Q's 91z28's Avatar
Car: 91 Z28
Transmission: Automatic
by any chance do you have the brake lines for the front LS1 swap for a third gen?
Old 02-11-2009, 10:24 PM
mark4iroc's Avatar
Car: 88 iroc
Engine: 355 tpi
Thanks for the parts!! Got mine today.
Mark
Old 02-11-2009, 10:47 PM
trumps2000's Avatar
Car: 1985 Z28
Got my part too, thanks again Ed!
Did you machine the block yourself? Nice work work if you did.
Old 02-23-2009, 02:35 AM
jersyboyy's Avatar
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
Hey so If I use this along with new hardlines(and make my own flares, one type for this fitting and the other type for the ls1 side)(and get new brake hoses from the hardline to the caliper) that should be all I need to have my ls1 rear brakes hooked up?
If so pm me wiht ur paypal info and ill take one off your hands asap.
Old 02-27-2009, 05:59 PM
86T/A.BBC's Avatar
Car: 05 Corvette Z06, 86 T/A Big Block
Engine: 468, 427, I6
Transmission: TH400, 6-speed, TF999
Axle/Gears: 3.42, 5.38
Hey Ed, if you have any left, I will take 1. PM me with the info for payment, thanks, Dan
Old 03-20-2009, 11:30 AM
jersyboyy's Avatar
Car: 85 Camaro
Just got mine finally and this is one AWSOME piece of work.
I wish I could get a good deal on the rest of the brake lines in stainless steel!
Thanks EB
Old 03-20-2009, 10:28 PM
palric's Avatar
Thanks all!
Ed
Hey Ed
still looking to pick up a set. Still have any left?
Old 03-27-2009, 03:53 PM
jersyboyy's Avatar
Car: 85 Camaro
Hey ed can you tell me what type of fitting and flare that t block is?
Is ita metric bubble flare or american double flared?
Old 03-29-2009, 07:40 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
still available // shipping overseas?
Old 03-26-2010, 03:17 AM
Superjustin13's Avatar
Are these still available Ed?
Old 03-26-2010, 10:57 AM
ebmiller88's Avatar
Not, at least not at this time. They are discontinued from Earl's so they are being custom made. I can let you know when they're available.
Ed
Old 05-28-2010, 10:24 PM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
_
Old 06-18-2010, 11:31 PM
1987CamaroZ28's Avatar
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Axle/Gears: factory 9 bolt with 3.45 gears
Ed
Hi. do you have any of the t block fittings? I stripped my driver's side T block fitting that goes between the hard line and back of the caliper.
Old 06-28-2010, 01:24 PM
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Ed
I need you help Ed. I went to your website and called your number and got a fax machine. I sent you an email. I'm looking for the "T" junction brake fitting that goes in between the left rear caliper and the hard line. It's a 9 bolt BW rear. Do you have any of these brass fittings?
Please help a brotha out. Thanks!
Reddeath210
10-06-2015 08:20 AM
kyleb24
08-15-2015 08:24 AM
Leggman1
Brakes
08-12-2015 08:39 PM
Ginamariegault
Brakes
08-10-2015 08:33 AM
Leggman1
08-06-2015 04:15 AM
Quick Reply: {SC} FS: Earl's braided rear brake lines, chassis to axle with "T" block
