[NC] plenum bolts and ignigtion coil bracket dual fan needed!
Car: 92 firebird
Engine: 305 tpi "stock"
Transmission: slipping
Axle/Gears: 3.42 posi disk brakes!
i need these bolts for the plenum
also the three that goes on the plenum part that hangs over the distributor
the bracket to bolt the ignition coil that bolts to the intake for a 305 tpi
and a daul fan (no wires just the fans and motors etc)
pm me or txt me 704 460 6394
also need a good goose neck or just those bolts lol
Car: 92 firebird
Re: plenum bolts and ignigtion coil bracket dual fan needed!
any bolts i hqave no clue the size for the part that goes over the distributorseeing if any one couldhelp i might give hawks a email
got runner bolts
got runner bolts
Car: 92 firebird
really need the bracket for the igntion coil to bolt to the intake manifold i do not have this?
Car: 91 Camaro RS
Engine: 305 TPI conversion.
the two manifold bolts on the rear passenger side had threads past the bolt heads. on the tbi manifold there was a bracket there to lift out the motor. i used the same two bolts and mounted the coil bracket to it. i have a coil bracket for it. ill try to get a closer pic of it fr you, otherwise you might be able to see what im talking about in the pics on the tpi conversion i did.
the alternative is to mount the coil on th firewall, using a custom bracket.
Car: 92 firebird
thanks man i was looking at into doing that qith the fire wall
or get a hei but idk if it will still fit uner the plenum cover for the distributor
Car: DEPENDS ON WHAT DAY IT IS
Engine: 428 STROKED TO 462
Transmission: 6 SPEED
I got one extra cover left and a pair of electric fans, take 100 bucks for all of it (might even have the coil mount)
Car: 92 firebird
fan have mounting brackets and workin motors
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Those three screws for the distributor cover are available from GM Parts Direct P/N 14083852.THOSE BUGGERS ARE EXPENSIVE
Car: 92 firebird
thanksfor the heads up
Car: 92 firebird
damn i should have asked for ten. . . . lol
post a pic in my book it onl;y shoiws onme bracket that bolts to the two intake bolts??
thanks guys
thanks guys
Car: 92 firebird
awesome come tomorrow considered sold
Transmission: 94 t56
Axle/Gears: 3:42 10 bolt
if you still need it i got the fans with all brackets and wiring, the bolts and the coil bracket make me an offer i need to sell broken arm and out of work so shoot me someething reasonable
Terrell351
06-13-2021 01:13 PM
