SLP 3.70s for Borg Warner 9 Bolt?
How much do you think it will help my 1/4 times?
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES Headers, Hooker Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.3 @ 97mph
L98 TPI 350 (5.7L)
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
with slicks you should break into the 13's
89 GTA 350 TPI(L-98)Fiberglass "Daytona Turbo" hood K&N filter air foil Stage 2 Fastchip B&M Stage 2 shift kit Flowtech shorty headers SLP 3'' exhaust Cams HI-6S igntion with PS-91 coil MacEwen white gauges overlay's SLP rear sway bar Koni's all around and one kick *** stereo!
Rice....it's whats for dinner
You can see a pic of it by going here:
http://www.hometown.aol.com/clarkemustgonow
I put 3.70 gears in my 9 bolt and I gained almost nothing in the 1/4. It was hotter outside that trip to the track though.
89 Formula 350
Rebuilt suspension, Aluminum Driveshaft, 3.70 gears
T56 siting in my garage till next months swap.
Best 1/4 mile - 15.08 bone stock.
89 Formula 350
Where do you get 3.70 gears from?
www.drivetrainspecialists.com ?
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
You get the SLP 3.70s from SLP.
L98 TPI 350 (5.7L)
L98 TPI 350 (5.7L)
I got mine from randy's ring and pinion. try finding the posi unit thought. that took some work... I had 2.77 at the begining..
89 Formula 350
89 Formula 350
If you have 2:77's in your ride you are going to have to change carriers too for a change-over to 3:70's. That means $$$$$$ Try to buy a whole rear end setup with 3:xx series gears in it. It's alot cheaper. I did it !
Bob R
(ROCN-Z)
89 IROC L98
Bob R
(ROCN-Z)
89 IROC L98
Car: 2002 SOM z28
I swapped in a 9-bolt 3.27 for my origional 3.23 open 10-bolt. It was rather straight forward. I think you can get a ring spacer, but that also might be for 10-bolts only. If you could find a locker or spool for a 9-bolt (I have never seen one), then that would be an alternative to finding a new (or slightly used) posi... good luck finding any of those though.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock... all the suspension stuff... 9-bolt posi disk is in... K&N filter... 93 octane...
I got the GO... I need the SHOW... Interior is next!
Where would I get a new carrier anyway? And what on Earth is a carrier?
L98 TPI 350 (5.7L)
L98 TPI 350 (5.7L)
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
So umm, me and dan are kinda screwed when it comes to swapping out our 2.77's for something nicer...(i mean screwed as in, just pop some new 3.45's in <-- that's what i want, and go...)
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-Rebuilt 700R4 Tranny
With the goodies to go
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
89 IROC-Z 350 TPI
-Flowmaster Catback
-K&N Airfilters
-Ported Plenum
With the cheap prices on ten bolt rear ends, it really makes more sense to buy a whole rear rather than just the gears for the 9 bolt. Granted, the 9 bolt is a bit stronger, but it still would not stand up to any REAL level of power.
Just as an example, I have a 10 bolt 3.23 posi rear end from a 97 Z28 that I got for 150 dollars whole, in perfect condition. I don't have it in yet since I have to get fourth gen wheels first, but those 17" SS wheels are lookin mighty tempting .
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
If anyone's got some spare 3.27 9-bolt gears, I'd be interested since I'm also running the 2.77's. If you know of any, please let me know!
-Craig
-Craig
UltRoadWarrior9
09-02-2015 08:24 PM
