Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Remote Starters
Old Dec 15, 2002 | 07:36 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Remote Starters
My Dad is thinking of putting a remote starter in his 2002 Silverado. He is considering Viper, Asto-Start, Ultra-Start, or Polar-Start.
Do you guys have any opinions on these brands?
Old Dec 15, 2002 | 08:15 PM
MdFormula350's Avatar
https://www.thirdgen.org/techbb2/sho...emote+starters
i ran a search couldnt find much, sorry...
Old Dec 18, 2002 | 09:28 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Thanks for the effort.
Old Dec 20, 2002 | 07:39 PM
CHRISMAN2000's Avatar
Car: 1991 Camaro Z28
Engine: 350 L98
I've got an ultra start in my junk car. Very nice quality no complaints. I'm very happy with it. It does what it's sapposed to and has yet to fail me.
Old Dec 21, 2002 | 11:18 AM
2vmodular's Avatar
A thirdgen remote start install guide is avaliable at:
http://www.p71interceptor.com/thirdgen/alarminfo
As for brands, they're all similar in the sense that they electrically emulate the ignition switch. Some things to watch for:
-Look & feel of the remote controls. Do you have a dedicated button for for lock & another seperate dedicated button for door unlock? Do you like the visual appearance of the remotes?
-Transmitter range
-Use of outboard which are easier to replace than onboard relays should they ever fail
-Many of the cheap generics have vague instruction manuals that contain errors and words jumbled together that do not make sentences.
A couple other notes:
You'll want the car to have some sort of fuel injection. TPI, TBI or even Crossfire should be acceptable. Installing a remote starter on a carberated vehicle is going to give you some major headaches.
Remote start with an automatic transmission is relatively safe, but is dangerous if combined with a manual tranny. There was a recent thread on this issue:
https://www.thirdgen.org/techbb2/sho...hreadid=146224
If you want keyless entry on your thirdgen, but do not have power locks, see this article:
http://www.p71interceptor.com/thirdgen/powerlocks
Old Dec 21, 2002 | 01:30 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I've used the one from Walmart called Bulldog a few times.
It's easy to install, works well, and has a few nice features. It's about $45. It comes with an instructional video that helps A LOT!!!!!!
The ones I used were from JC Whitney, and I also got the power door lock remote with them so they were about $65. I don't know what other features the $45 one at Walmart has.
Old Dec 21, 2002 | 02:32 PM
BigL350's Avatar
Considering the truck has Passlock II, I wouldn't go with anything other than a DEI product (Python, Viper, Valet, Automate, etc.) Their Passlock interface, the 555L is the ONLY Passlock interface I have seen work for long periods without causing problems in the car. Make sure you have a competent shop install it, too.
Old Dec 22, 2002 | 11:35 AM
2vmodular's Avatar
The dei passlock bypass unit can be used with other brands of remote starters too.
The dei 555L electrically emulates the hall effect in the lock cylinder when the remote starter is engaged. There's another non-dei unit on the market that captures the databus signals between the passlock module and the engine module and then will reproduce them as needed. No cutting is required to install the databus module, just strip some insulation off one of the wires on the underdash obd2 connector and connect the bypass wire to it.
You can attempt to make your own bypass unit with a couple resistors and relays, but there is some concern about these setups changing their effective resistance value significantly enough when the temperatures are low that the truck won't start. Likewise, the bypass boxes with dip switches on them are not too reliable either.
Old Dec 23, 2002 | 11:08 AM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
I have an Avital Avi-Start 3200 system (made by DEI) on my Isuzu Rodeo daily-driver. I love it. One thing I found out is that if you have keyless entry already on the Silverado, you'll have to either carry 2 remotes or get the keyless entry option on the remote start unit. That's what I did. Actually, I had to, since the lock/unlock buttons on my factory remote did not operate when the truck was running. If that's the case with the Silverado, you'll have to get the keyless entry option on the remote start also.
And I agree with 2vModular, get a brand that has a remote that you like. The Avital has a nice looking remote. A co-worker of mine had an Audiovox remote start put on his truck and it has the most ugly, mishapen remote I've ever seen.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
