Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
MSD Ignition?
Old Apr 10, 2003 | 08:15 AM
Virus101487's Avatar
MSD Ignition?
i dont have any mods on my car yet. i was planning on adding the msd ignition first. would this be a smart move or not? if so then what all do i need to get with which system?(plugs, wires, distributor, etc.)
Old Apr 10, 2003 | 09:06 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It would be about the last thing I'd do. You won't see much benefit, if any, on a stock engine.
Old Apr 10, 2003 | 09:56 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I agree....I have one..didn't really notice to much with it....just a much smoother idle....got mine for a good deal..that's why I bought it...
Old Apr 10, 2003 | 02:42 PM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
i agree with the last 2 guys. I'm making 400+hp and i knowdist 0 inprovement at idle or wot over the stock hei. I was a little .
Old Apr 10, 2003 | 02:45 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
The 6AL does have a rev limiter, which is nice, but as far as noticable performance improvements go, there are better things to spend money on (especially with a stock car).
S-D
Old Apr 13, 2003 | 01:49 AM
25THRSS's Avatar
I hear you get better gas mileage with it.
Old Apr 14, 2003 | 04:53 PM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
MSD Advertises their 6A(L) boxes will improve power, quicken throttle response, smooth out idle and starting, reduce spark plug fouling, improve mileage and reduce emissions. All sparks, including each multiple spark, is 110 milliJoules of spark energy. Steps up the primary voltage to 470 volts. Spark series lasts for 20° of crankshaft rotation. Operates at full power with a supply of 10 - 18 volts and will run down to 5 volts. Cast aluminum housing and Humi-Seal coated circuits protect the electronics. Can be triggered using points, electronic ignitions or magnetic pickups.
I think the biggest argument against the MSD box is that if you throw a lit match into a puddle of gas, it'll all burn, so how would throwing hundreds of tiny matches help? You'd be suprised; I'm a believer in the box and feel it makes a fine addition to any vehicle in any stage of modification.
Old Apr 15, 2003 | 10:25 AM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
i picked up an msd6a for free after doing a job for a fella, and i installed it in my vacum advance carbed car... i felt a rather large gain over the previous igniton- and i had a racing module, and all the good parts in the distrrbutor. now that the msd is acting as the module (i'm using the magnetic trigger pick up) i've honestly felt a pretty good difference.
I can't necesarily speak for idle quality, but bottom end power is much stronger, and smoother. For sure my throttle responce is also better, and cold and hot starts are better...
as for mileage, i didn't notice any difference. and i havent been to emmisions yet, but i'm sure it wont help me pass
Old Apr 15, 2003 | 02:44 PM
so for the final answer lets see a raise of hands if it helps out or not(yes or no)
thx again all
Old Apr 16, 2003 | 12:46 AM
25THRSS's Avatar
i would have to say yes
Old Apr 16, 2003 | 12:50 AM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Axle/Gears: Various
Yes
Old Apr 16, 2003 | 10:25 AM
90form305tpi's Avatar
Car: 1990 Firebird Formula 305
Engine: 305tpi w/145,000 on the clock
Yes, but, I would only get it once you have modded the car a little. I did mine after my intake and exhaust mods(see sig). I did notice it helped make more power at the top of the power band. Throttle responce was much nicer, and my gas mileage improved a lot. But I also have the coil, good cap and rotor,8.5 milli's, and U-groove plugs that are gapped at .55.(stock was .35). So it may not be just the box, but it definately kicks the stock ignition's ---!
Old Apr 16, 2003 | 10:37 AM
Shagwell's Avatar
Car: projects.......
Deffinitely yes, but I wouldn't for a first mod. Do it later when it will make more of a difference.
Old Apr 18, 2003 | 09:49 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
Re: MSD Ignition?
i wouldnt go with the full MSD ignition...but i would change some parts. i would definitely get some new wires, and a new cap and rotor. then next would be a coil, but even that isnt totally necessary. i would definitely skip the ignition box on a stock car...that would be a waste.
just my opinion..
-brian
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
meeklay812
Oct 1, 2015 03:46 PM
RedLeader289
Sep 23, 2015 06:50 AM
