Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
MSD Digital-6 Plus vs. Holley Strip Annihilator
Old Oct 27, 2001 | 09:56 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
Who has one of these and what are your thoughts on them?
I know they are both microprocessor controlled and have rev limiters, but the Holley is adj. from w/in the ****pit. Price is only $20 different.
So who has what and do you like it? Has is lasted long or given you any problems? Thanks.
89 IROC-SuperRammed 355 w/ AFR 190's and LPE 219/219 cam-http://www.geocities.com/buckeyeroc
Old Oct 28, 2001 | 05:50 PM
Mark W. Winning's Avatar
I was looking at both, but a few friends of mine are very good bracket racers. In their group of friends there were some problems with the new Holley units, so I bought the Digital 6 and could not be happier with it. Maybe Holley was just having the new problem blues, but I was not going to take the chance...
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old Oct 31, 2001 | 09:36 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
My question is: What do the racers run? When I go to the track all I see are msds new and old. That says something.
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Old Nov 6, 2001 | 08:42 AM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
IMHO go checkout Jacobs Electronics for ignition mgmt systems. I've used them and they REALLY produce power.
The racers use MSD because they don't sit in traffic jams idling away for hours on end travelling to and from work.... different systems for different applications. think about it ?
RP.
'91 Formula Firebird G92,WS6,5-speed,3.42 a ton of fun to drive.
Old Nov 6, 2001 | 06:21 PM
The only MSD that I have used that hates street use is the 7AL. Even then it seems to be more coild related. My 6AL and Digital 6 see massive street use without complaining.
Old Nov 19, 2001 | 03:07 AM
crazeinc's Avatar
I run a Digital 6 in my daily driver
'90 GTA...nitrous is your friend
Old Nov 19, 2001 | 01:14 PM
MSD tech's Avatar
palric,
I have noticed in your posts on ignition questions that, you always put "The racers use MSD because they don't sit in traffic jams idling away for hours on end traveling to and from work". I am not trying to stir anything up or knock any other manufacture but this statement is just not true. All Of our 6 series ignitions are designed to function on daily driven applications, sit in traffic etc., with out any problems at all. Even the MSD 7AL-2 box can be used on a daily driver with the correct coil. I am not trying to push MSD, I just wanted you to know the actual truth.
Thanks,
Joe
Old Nov 21, 2001 | 04:35 PM
a73camaro's Avatar
Does any one have any 1/4 mile improvements to post.
I went from stock ignition to MSD7 with no gain.
Old Nov 22, 2001 | 08:59 PM
BuckeyeROC's Avatar
a73camaro, did your car seem to run any smoother, better throttle response, better anything?
Old Nov 27, 2001 | 07:08 AM
PROCHARGED89Z's Avatar
<font face="Verdana, Arial" size="2">Originally posted by MSD tech:
palric,
Thanks,
Joe
</font>
Just a question ,when should someone consider movign up to a 7 al?And what coil can be used in conjunction with it on the street?
Old Nov 27, 2001 | 10:49 AM
a73camaro's Avatar
The addition of the MSD7 box definitely made starting the car easier when compared to the "stock" electronic ignition. It is a 13.5:1 compression engine with a ~310°, ~0.600" lift cam.
Old Nov 27, 2001 | 11:13 AM
MSD tech's Avatar
We recommend up grading from the standard 6 to the standard 7 box when your compression is above 13-13.5:1. The digital 6 does produce more output then the standard 6 so it will be capable of more.
Old Nov 28, 2001 | 06:11 AM
High compression?Does this include forced induction cars?
Check out my Hompage,or the beginnings of one.355 dynoed at 400HP at 5800RPM & 410LBFT of TQ,on Motorhttp://www.procharged89z.cz28.com/index.html
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
