Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
H4 Sealed Beam Conversion Set from Ebay ID automallinc
Old Nov 21, 2005 | 04:22 PM
  #51
87IROC350's Avatar
Engine: 5.7
Here are some additional ones I found:
automallinc
2004momo - comes with adapter
I bet the 7x6 is a typo....
Old Nov 21, 2005 | 05:38 PM
  #52
cocacolakidd's Avatar
Car: 84Z & Porsche
Engine: 427sbc - 471 - 850 Demon Claw
Transmission: Bowtie stage II TH700R4 - 10" 3000
Axle/Gears: 9 Bolt w/ 3:45's
Automall inc has the 80/100w Bulkbs they say will work...well the are to hot and start the wiring to over heat - 55/60watt bulbe are the norm.
2004 Momo are the ones I have and are a great set. They include the wiring to re-do the setup complete now. Otherwise you have to figure how to repin the lights. Which I think is mentioned above in this thread. Because many of us had to do this.
Just my thoughts ~Ed~
Old Nov 21, 2005 | 05:39 PM
  #53
Car: 84Z & Porsche
I'll bet 5cents that the 7x6 is not a typo - A friend got them , and they are 7x6.....boooo-
Old Nov 25, 2005 | 03:25 PM
  #54
87IROC350's Avatar
Engine: 5.7
I sent the guy an mail to the guy and you are right. He said people buy them to convert them to the larger size. Go figure.
Old Nov 25, 2005 | 04:05 PM
  #55
Car: 84Z & Porsche
This guy is full of it - Just think of what the conversion to that large of a light in the front of a Third Gen would cost. Big cost to convert with very little gain - if any. Nope he's full of Sh**. Just who is he kidding? Don't get the ones from him...
Just my 2 cents worth. ~Ed~
Old Nov 28, 2005 | 11:41 AM
  #56
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I'm using the Momo lights as well. They seem to be fine, came with the factory sized bulbs.
Anyone have an issue with installing the with the "TOP" lettering up or down?
Old Nov 28, 2005 | 07:13 PM
  #57
Car: 84Z & Porsche
Hello Vernw,
Well I have never thought about that. Mine are installed with the small cruse light on the bottom - Without taking them out
I do not know if they are in top up or down. I would think that it would not matter if they will go in upside down. The only thing would be the wiring would then have to be upside down. With the wiring conversion (Cross pinning) there's plenty to play with. All four of the mount stops, on the back top edges of the housings, are in the same position on both lights - So, humm, good question. ~Ed~
Old Nov 28, 2005 | 07:54 PM
  #58
ratrodjon's Avatar
Car: 89 CAMARO, GUTLESS WONDER
Engine: 305 TBI
I think the only reason the top is indicated is because their are 3 or 4 nipples in the headlight used to attatch headlamp aiming devices. The reflective back may also have a different shape to diffuse the light correctly. Most headlamps i've dealt with wont sit in the bucket correctly if it is upside down, but i've never changed my lights so i'm just full of sh**.
Old Nov 28, 2005 | 08:23 PM
  #59
vernw's Avatar
On my MOMO's I also have the the blue cruise light on the bottom. All their eBay pix show it on top. And my front clear glass plate has the letters "TOP" on it, and to get them to focus clearly and have the "correct" light pattern IMO I had to put the "TOP" "down"....
And FWIW, the nipples on the back are symmetrical so they'll fit in the light buckets both ways.
Old Nov 29, 2005 | 04:36 PM
  #60
Car: 84Z & Porsche
Hello VernW,
Well seems as if you are correct. When I was fiddiling with them, to get them to show better. I must have turned them over, and did not notice the "top sign." So my dims have the top on the bottom, and the brights are on the top. So I will have to agree with you that they do shine a better, wider pattern on the road when up side down. My bright lights, also from Momo, are better when installed top up. Go figure - humm.
Have pfunn ~Ed~
Old Nov 29, 2005 | 04:44 PM
  #61
vernw's Avatar
87iroctheo
Wheels and Tires
Sep 2, 2015 03:29 AM
Dialed_In
Aug 20, 2015 01:45 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
