What type of headers?
Car: 1989 Camaro IROC-Z
Engine: L98 350 5.7L V-8 (Ram-Air)
Transmission: TH700R4 with stock 2.77
I have a stock 1989 camaro irocz with the 350 in it. I want to put headers on it. But im not sure with what type to go with. I would like to get long headers and NOT the shorty style. But with long ones can they be direct bolt ons? So basically i would like to get all of your opinions on what type of long header (direct bolt on) would be good? thanks
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Wrong board...
Tutorial for Long Tube Header Install
What's the BEST exhaust? What's the BEST header? Post
3rd Gen Header Option Chart - Explained Post
To my knowledge there is no direct bolt on LT header.... Heck even most shorties require at least some cutting and welding.
so ive read alot about it i guess headman 2055's are the best choice even though they are shortys....
You have all of 2 options in long tubes, Hooker or Headman. Headmans won't clear a factory manual trans(hyd slave cylinder), and the Hookers hang a little low for my taste. One way or he other, you'll be doing some "trimming" to get them in. But, as stated, you'll be doing some trimming to get just about any headers in our cars. - I do like my headman's though...I'd keep them if I wasn't going so drastic with the car(full frame, aluminum rear tin, coil-overs, etc..) My new ones will be hand built. - Mine are going to a friend...
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
As far as I know the 2055's are the only equal length shorty's out there....but don't quote me!
I love mine EXTEMELY easy to R+R! U can actually get them in and out without scratchng them! (if U are careful of course!)
Car: 1989 IROC Z-28
Go to Summit and use their search feature--it's really quite easy to find all the info U want. Click on online store from the main page and go from there.
OK-2055HKR
$389.95
Estimated Ship Date: Today
overview Application Show All
Brand: Hooker Headers
Product Line: Hooker Super Competition Headers
Header Material: Steel
Header Finish: Painted
Header Style: Shorty
Primary Tube Diameter (in): 1 5/8
Collector Diameter (in): 3
Equal Length: Yes
Primary Tube Gauge: 18-gauge
Collector Attachment: Stock flange
Cylinder Head Port Shape: Oval
Flange Style: Standard
Flange Thickness (in): 5/16
Bolts/Studs Included: Yes
Gaskets Included: Yes
Reducers Included: No
Y-Pipe Included: Yes
Quantity: Sold as a pair.
OK-2055HKR
$389.95
Equal Length: Yes
Car: 88 Camaro
Engine: L98 350
Well satisfied with my Edelbrock TES, but then again Hooker is probably the top name in headers. Be sure to get the Y-pipe that goes with the headers, that is a really curved and bent up piece. The TES has it with the header kit.
yes, you'll have to replace the y-pipe to go with ANY headers you get. - why wouldn't you want to? stock "t-pipes" are ungodly restrictive. - if you go shorty, I would say hooker...
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Hooker 2055's "seem" to be the favored headers/Y-pipe on this board. No problem with fitment with mine. Those, along with a Catco high-flow cat and Hooker catback, are highly recommended.
JamesC
JamesC
Car: 1989 IROC Z-28
The only thing I don't like about my 2055's/y-pipe is that the y-pipe just before it hoks into the cat, hangs pretty low and there's not much U can do about it. On my car it is lower than anything else and I just got thru replacing the y-pipe because some speed bumps got it and crushed it to about 1/2 the diameter of normal.
The pipe does hang a bit low, though I've experienced no clearance issues at this point. A lowered car, however, might experience some real difficulties.
JamesC
JamesC
Car: 1989 IROC Z-28
Originally posted by CRZYTRN-92Z28
Really!?! I freaking hate mine and will upgrade to longtubes the first chance i get.
LT's deffinitely take some work to get them in. Nothing major if you have access to a smoke wrench. I do believe they're worth the work, but just run a y-pipe and good cat-back. Duals isn't worth the work. You can make just as much power w/ a good single exhaust as you can w/ duals.
Car: 1989 IROC Z-28
Car: 1992 Z28
Engine: 350 L98 w/ D-1SC
Transmission: POS 700-R4
Long tubes are even worse Dude!
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
i have hooker 2055s and love them. yea the Y hangs a tad but i havent had any serious issues with that and im lowerd. i HIGHLY sugguest getting the Y pipe as i was waaaaay impressed with its design of flow where the pas and dr sides merge. i run a magnaflo cat and it slips right on. iv heard controversy about the catco but nothing direct.
my hookers are fairly easy to work around for headers and 2 of my friends bought the hooker 2055s because i was so impressed. one of our F.A.S.T. engineers bought a set for his camaro and was impressed how they went in without headach and no lifting of the motor. i put mine in with the motor swap and loved having no clearance issues of any kind.
PS, get them coated!!!!!!!!!!!!!!!!!!!!
hooker 2055s
Hooker LT's
Chad Speier
Sep 24, 2015 12:32 PM
Hello, Michael
Sep 11, 2015 01:10 PM
