Fuel Pressure Regulator
Car: 1988 GTA
Transmission: 700-R4
Axle/Gears: 9-Bolt 3.27
I'm looking to buy a new FPR and was wondering what's the best brand to buy.
Originally Posted by G-Ride14
what about the BBK one?
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
Diddo, I have the BBK one as well. Spend the extra 20$ it's well worth it. I wish I would have.
1 Post
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I have the Holley AFPR, and like it alot. Once it is installed, no tools required to adjust the fuel pressure.
Tip: Before removing your stock FPR, measure your current fuel pressure. After install of new AFPR, adjust the fuel pressure to what you had before as a starting point.
I checked mine, 48PSI with vacuum off. Not worth spending the $ for a adjustable one right now. After I do a few other things I'll pick one up and port my plenum. I had a Breathless performance one on my GTA, www.breathlessperformance.com. They have them for $66, and they look to be the same as the TPIS one thats $90.
Car: 86 Monte carlo ss
Engine: tpi l98
I was looking for a holley adjustable fuel regulator. I came up with pn 510-512-501. It is listed as 5.0 tpi. I cannot find a holley that fits a 5.7 tpi engine for holley. Will the 5.0 model work. I imagine it should fit. It's adjustable up to 65 psi.
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
it will be the same unit. fuel rails for tpi f-bodies are the same from 85-88 with rear port for 9th injector. 89-92 they are the same without port for 9th injector. doesn't matter 5.0 or 5.7
9192camaro
16
02-03-2019 12:21 AM
