Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
hypertech prom chip
Old May 3, 2008 | 10:07 PM
RicksIroc86's Avatar
Car: 84 camaro z28
hypertech prom chip
http://store.summitracing.com/partde...5&autoview=sku
would that chip make any kind of difference on a 89 firebird with a 305 TBI that has ngk plugs, 8.5 msd wires, msd blaster coil and cap and rotor and an accel ICM and a K&N air filter and other than that totaly stock?
im just trying to see before i blow 120 on something if it dont do anything
thanks
Old May 3, 2008 | 10:50 PM
Car: 84 camaro z28
Re: hypertech prom chip
i have been reading different posts and have learned that these suck ***. so if someone will tell me how to delete this post i will
Old May 3, 2008 | 11:10 PM
85irocz355tpi's Avatar
Car: 85 IROC-Z
Engine: 355 TPI
Transmission: 700R4w/Shift Kit
Axle/Gears: B/W 9 Bolt-3.45
I recommend the hypertech thermomaster chip. I have one in my 85 tpi iroc. I have used it for 5 years now and havn't had a problem. I have used it with both the 305 and my 355. It lowers the temp that the fan comes on and gives it a more aggressive spark curve. You'll have to replace your thermostat to a 180 degree one to get the benefits of the new chip. I think there worth it but that's just me and mines tpi also.
Old May 4, 2008 | 12:45 AM
Guro 305's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: 305 carb'd V8
Transmission: 4-speed auto
Axle/Gears: Stock
I'll buy that.....about the thermostat anyway. I noticed it ran alot better with a thermostat at 180 rather then the 165 recommended by Hypertech.
Old May 4, 2008 | 09:24 AM
Car: 84 camaro z28
would i be able to just put in the termostat with out the thermomaster chip? and how much and where did you get the thermostat?
Old May 4, 2008 | 01:15 PM
Car: 85 IROC-Z
Engine: 355 TPI
The thermostat runs about 7-10 bux from your local parts store. You can put just the thermostat in but it won't turn the fans on earlier so in traffic it will still run just as hot as it does now. You can hot wire the fans to come on with the key though. I still recommend the chip though.
Old May 9, 2008 | 10:38 AM
Shribe's Avatar
Car: 1988 IROC
Transmission: 700 R4
Axle/Gears: 2.77
I never thought I would purchase one after reading the boards, but my latest car came with one and a stock chip. I tried it both ways and it has more power with the chip in, and I am checking the gas mileage. It also is the only IROC that I have owned that runs cool, and even did up in the mountains where I crept to 210 every time I drove up the driveway with the previous car. I will post what the mileage difference is. All my cars have been TPI, I don't know if it would work as well on a TBI.
Old May 9, 2008 | 05:48 PM
Car: 84 camaro z28
oh ok thanks
Old May 10, 2008 | 05:22 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
A note on the t-stat: For the TPI engines, from what I've read, the best comprimise is a 170* t-stat. I know of only two places to get one. The dealerships sell AC Delco and TPIS sells one also. From what I understand the TPIS one is just a reboxed Delco. You have to have the p/n when ordering from the dealership. If you ask for a 170* t-stat they'll tell you it doesn't exist 'cause it won't pop up on the computer. The p/n is 10220957. For more info on the coolant system, read the Total Fan Control article found in the tech articles:
https://www.thirdgen.org/electric_co..._spec_mod_dual
Old May 10, 2008 | 09:06 PM
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
buy the thermoaster hypertech chip
Old May 14, 2008 | 08:00 PM
Car: 84 camaro z28
ok so i am in the process of getting set up for the thermomaster, i just replaced the thermo stat with a 180 degree one and now trying to figure this 180 degree fan switch.
Old May 14, 2008 | 08:47 PM
Car: '87 Iroc-Z
just wire you fans to come on when you turn on the ignition,thats how mine is setup and my temp never goes over 200 degress unless im oon the high then it sits at about 215
Old May 14, 2008 | 09:56 PM
Car: 84 camaro z28
yea thats how my iroc was set up, would i just run the wire from the fan moror strait to the battery?
Old May 15, 2008 | 03:55 AM
Car: '87 Iroc-Z
that I couldnt tell you,mine came like that when i bought it,i think its to the red wire inside to the ignition on the fuse box
Old May 21, 2008 | 05:22 PM
CamaroKingpin's Avatar
Car: '92 camaro rs
Engine: 3.1 v6
Transmission: stock tranny
Axle/Gears: stock gears
what about the hypertech chip for hp? they say it will add up to 23 hp for stock to mild mods. anybody know? and would you need th programmer as well? is it pre-tuned or could you take to get tuned?
Old May 21, 2008 | 06:05 PM
Car: 84 camaro z28
send me a link to the one you are looking at, i havent seen it yet.
thanks
Old May 21, 2008 | 08:01 PM
88tpi350's Avatar
Car: 88 formula
Engine: 350 goin carb
hyperjunk period. look into some sites that will do custom chip burning. all hyperjunk does it advance the hell out of the timing and make your fans come on sooner. woo.
Old May 21, 2008 | 08:11 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
for a stock to lightly modded car.....its worth it rather than getting a custom chip
Old May 21, 2008 | 09:45 PM
Car: '87 Iroc-Z
people just need to stop downing chips, NOT everybody has dough just to dish out for some custom chip. Hypertech and JET chips are fine for stock to midly motors, dont worry about custom chips until performance mandates it.
just my 2 cents
Old May 21, 2008 | 10:06 PM
Car: 84 camaro z28
yea i mean i have never tried one so i would give it a ****. but does anyone have a link to the chip that can supposedly add 20 horsepower??
Old May 22, 2008 | 03:04 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Stop downing chips? Burning my first chip (admittedly, a direct copy of my current chip) cost me less than $100. Last I checked those Hypertech chips clocked in at $250. Who doesn't have the dough now?
Old May 22, 2008 | 09:33 AM
Car: '87 Iroc-Z
actually 149 but whos counting, and u didnt include cost for chips or equipment, sure u can make better chips yourself but at least give people the time to learn and grow. DAMN
im not shamin burn u own stuff im just sayin let people make their own decision, isnt this hobby about personalization
Old May 22, 2008 | 05:32 PM
Car: '92 camaro rs
Engine: 3.1 v6
i didnt know about burning your own chip. what would i need for this. id rather do my own any links?
Old May 22, 2008 | 06:44 PM
Axle/Gears: 3.27 BW
http://www.moates.net/
Plus the DIY prom board and tuning board here. You can pick up a Willem Eeprom programmer off of ebay. Get one that requires external power, the USB port on your compy doesn't provide as much power as is needed most of the time. The eeprom programmer can be as cheap as $20 (What I paid) or as much as $100 (Programs any chip. Ever.) the programmer also allows you to read chips. You can also buy an all-in-one kit from Moates.
A little bit of research here goes a *long* way. Have fun.
Old May 22, 2008 | 07:50 PM
Car: '92 camaro rs
Engine: 3.1 v6
www.autopartswarehouse.com/search/?N=9891+1558+4294967006+9349
this is what i was talking about that adds up 23hp
Old May 22, 2008 | 08:34 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
link doesn't go to anything, I wouldn't count on it adding that much hp though.
Old May 22, 2008 | 08:48 PM
Car: '92 camaro rs
Engine: 3.1 v6
thats the address i copied.when it goes autopartswarehouse.com , its a jet performance chip stage 1, for 82-92 camaros. i got a 1992 3.1. id spend $160 for 7-10 hp.
they also sell the kit with the different chips for different ranges of needs for like $350.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
dusterbd
Sep 29, 2015 08:40 AM
