Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
HEADLIGHT COVERS ???
Old Apr 9, 2011 | 09:07 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
O.K. , i know this subject has been beat to death . i have SEARCHED , but i have a question . i found on ebay and followed to summit some headlight covers . they appear to be different from the ones that fly off . o.k. , i know the factory made/supplied some . these seem to mount a little different . summit pn# 37615 , has anyone tried them ? if so please post results . not interestd in a bunch flack (but i know it will come) , just interested in summit pn# 37615 . thanks for any info. on them . good luck to all .
Old Apr 10, 2011 | 03:33 PM
UNCLE TOM's Avatar
Re: HEADLIGHT COVERS ???
bump ............
Old Apr 16, 2011 | 02:46 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
pics dont look like the would fit the camaro... camaro has 2 headlights. It looks to have the right curvature for the firebird covers, however they wouldnt work since firebirds pop up and that wount cover the actually headlight but looks more like the shape of the cover thats already a solid piece of aluminum.
Make your own
Old May 3, 2011 | 09:42 PM
DRIVE2FAST's Avatar
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
IM CUTTING A SET OUT OF 1/4 PLEXI -GLASS. ILL POST PICS WHEN DONE.
Old May 12, 2011 | 11:01 PM
irocket87's Avatar
Car: 87 Iroc Camaro
Engine: 5.0
ive also been wondering how the headlight covers mount since our headlight are pushed back in the front end and the covers dont fit flush on the headlights like most cars? heres a link with some for sale they all say no tools or drilling required? would you use some sort of doublesided tape?
http://cgi.ebay.com/ebaymotors/AVS-H...Q5fAccessories
Old May 15, 2011 | 02:03 AM
irocket87's Avatar
Car: 87 Iroc Camaro
Engine: 5.0
no one has headlight covers or ever used them or what?
Old May 15, 2011 | 07:43 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
1) Never used them..
2) Never liked them..
3) Useless add on..
My opinion....
Old May 15, 2011 | 11:29 AM
mongo136's Avatar
Car: 89 camaro rs
Engine: 468 bbc
Transmission: powerglide
Axle/Gears: 373 S-60
I used to use them, not sure of part numbers but mine never came off. They tucked under the hood and used a bristle like attachment on the bottom. It was like velcro but stronger. Just repainted, not sure if I'm gonna put them back on or not.
Old May 15, 2011 | 07:16 PM
irocket87's Avatar
Car: 87 Iroc Camaro
Engine: 5.0
well i think they look pretty good on a third gen. i just want to know if theres anything that usually comes with them to mount them or install them
Old May 15, 2011 | 07:24 PM
one wheel peel's Avatar
Car: 84 camaro
Engine: 72 chevy 406 sbc
Axle/Gears: 3.42 eaton posi
i got em on mine , and i like em, never flew off, been to 120 no problem
Old May 16, 2011 | 09:49 PM
irocket87's Avatar
Car: 87 Iroc Camaro
Engine: 5.0
what comes with them or do you use to mount them and where did you get them One Wheel Peel?
Old May 17, 2011 | 06:11 AM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
I had a set once that had our 3rd gen Z28 emblem embossed on the lower outside corners. Flew off on my way to Ft Madison, IA because the mount broke/cracked. Found it, superglued the pee pee out of it when I got to town, and was fine for about 2 more months. Same cover is somewhere between Lincoln and Omaha. Didn't even see it fly off the 2nd time.
I have another set that I plan on installing this summer. I like the look myself.
Old May 17, 2011 | 07:20 AM
Car: 84 camaro
i got them at auto parts store called hires, they have a plastic chanel that is screwed to inside of headlight pockets, then u need to slightly bend cover to get them to slip into channel. but dont try to bend when they are cold, they will snap easily
Old Jun 26, 2011 | 10:18 AM
ZROCz28's Avatar
we have them on our drag car they actually saves us 2 10ths and 1 mph on our runs, it blockes the air from being collected in the headlight pit and reduces drag
Old Jun 26, 2011 | 12:06 PM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
You have a picture? Ive seen bucket covers on drag cars, lexan, and either pinned or fastened in. But never an adhesive backed or velcro strip. That would be very unprofessional and I am pretty sure many tracks wont let you run with that crap on.
Old Jun 26, 2011 | 02:03 PM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
I had smoked ones when i bought my car,.. the clear ones look nicer and I never had them fly off.
Old Jun 26, 2011 | 03:16 PM
UNCLE TOM's Avatar
back to subject , no one has tried summit pn# 37615 ???
Veaceonee
Sep 29, 2016 08:15 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
