Jegster Bolt-on subframe connectors
#51
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Re: Jegster Bolt-on subframe connectors
I bolted in my jegster subframes while my car was on ramps and jackstands. i have yet to weld them but i do check the bolts everynow and then. i also put on a set of topdown solution tubular subframe connector with no interference at all. the car is as asolid as it can be.
#52
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Not trying to be a jerk,and it may work but you still could not pay me to clime under a car with the front stands like that, I don't care how many times it been done.The lower control arm is just on the other side of that wheel and is considered a jack point that will accomplish the desired effect.
Nice looking car "InfernalVortex"
#55
Car: 1989 Iroc Z 5.7L
Engine: 5.7L
Axle/Gears: built 4.10s
I just ordered a set of the jegster subframe connectors for my street car.
http://www.jegs.com/i/Jegster/550/40053/10002/-1
I have no welding experience so I will be bolting them in then taking the car to a local shop to get them welded up.
My question is, does anyone have recommendations on how and where to weld these up on the thirdgen chassis? What type of welder should be used? Where are the best areas to weld them to maximize the benefit without over welding them.
#56
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
I welded mine around the very back radius of the sub frame connectors where they meet up with the LCA mount. A few stitch welds along the pinch welds on the rockers can't hurt either. Then just to the floor up front around the perimeter on the flange where the bolts go through. That should work. Make sure the car is even supported, preferably sitting on all 4 wheels so when it's welded the car isn't flexed in any abnormal direction.
#57
Do you think that if the front tires were on ramps and the back tires were on the ground that the suspension would be loaded differently?
#59
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
competition engineering has a much better set IMO
#60
Engine: 5.7L
I considered those, but for my street car I free these on the perimeter will give added safety and rigidity without impacting ground clearance. I don’t want to see them when I am walking up to the car like some of the other solutions.
#61
Engine: 5.7L
#62
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
I had a hard drive crash a couple months ago or I could tell you my specific heights but I recall the front was under 26"(25 3/4" iirc) & the rear 27"(27 1/2" iirc).
http://www.top-downsolutions.com/cha...8aka-f-body%29
CORRECTION:It is the Alston's that I have.
#63
Engine: 5.7L
I feel that they are a much stronger design due to the fact that they actually connector factory subframes whereas the rears only get near them & not actually attached to them. I noticed no ground clearance issues than I did before installing them with my low ride height on Ground Control Weight Jacks & not much room left to adjust them down much further.
#64
1 Post
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
Agreed ... I have their older design that tucks up in the rocker panel area ... They were bolt in style do I bolted them in with extra/bigger washers then went back and welded em in .. I found em on craigslist locally paid 100$ and they were brand new with all hardware instructions etc. Still in packaging
91' bird 305 TBI T-5, trick flow 175 cc heads, 4.10 gears, lots of suspension upgrades. 24mpg @ 2500rpm hwy. 8.80@ 84mph 1/8th on street tires... 8.000's soon
#65
Car: GTA
Ooops.......My bad. It is the Alston's that I have. Got them from TDS. http://www.top-downsolutions.com/cha...8aka-f-body%29
#66
Car: 1984 Z28
Engine: 5.0 V8 HO
Axle/Gears: G80 3.73
Sorry for reviving a 4 year hiatus thread... It looks like JEGS no longer makes their connectors under the Jegster title. Can anyone tell me if these look similar to the ones mentioned throughout this thread? I looked at the photos in this post and they look close but wondering if anyone can confirm.
https://www.jegs.com/i/JEGS/555/64714/10002/-1
Also, can anyone say that with 100% certainty they have both the JEGS/Jegster/SPHON SFC's and TDS/Alston's SFC's installed at the same time without issue? I am getting ready to make a decent sized order at TDS and am considering adding the SFC's at the same time if I can install them also with the Jegs/Jegster or SPOHN SFC's later on.
Thanks!
Thanks!
#68
Car: 1984 Z28
Engine: 5.0 V8 HO
Not really... As mentioned in my post above, it looks like Jegsters are no longer available so I am trying to confirm if Spohn or Jegs SFC's(trying to confirm these are the same just rebranded Jegsters) will work in conjunction with the TDS/Alstons. Are these forums not a place for people to ask for help and have meaningful adult discussions about a shared interest in the 3rd gen platform?
in advance for anyone who can offer a helpful answer to the question I asked! If I should open my own thread for this please nicely let me know and I will be happy to oblige.
#69
the jegs sfcs you linked to are the exact same as the older "jegster" brand. Jegs did away with the "jegster" line realizing that there was no need for 2 different brands within the same company.
the spohn sfc's are completely different than the jegster, but both will work with the alston/mac type inner sfc's.
#70
Car: 1984 Z28
Engine: 5.0 V8 HO
Also, that is one bad a$$ Sport Coupe!
#71
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Back from the dead....again
Any pictures of the Jegs SFC with the Alston/Mac type inner sfc's?
#72
Car: 90 Formula / T-tops
Transmission: MD8
some alstons over here, would like to get a closer look at a jegsters installation photo wise. kind of sad they ship with grade 5 hardware.....
starts at post 41
https://www.thirdgen.org/forums/susp...-bushings.html
starts at post 41
91banditt2 (07-01-2020)
#73
Transmission: MD8
do the jegsters really count as "subframe" connectors. more like connecting rear subframe to front floor boards it seems after looking at install directions.
#74
Car: 1989 Trans Am
Engine: 305 H.O. TPI
Transmission: Auto 700R4
Axle/Gears: 3.42 posi
For what I need I think the Jegsters will work just fine for me, my car is pretty tight for a 31 year old car, if it will stiffen it up and get rid of or reduce the minor squeaks and creaks I have at he T-Tops that will work for me. I have no plans of 500 hp or drag racing, if I did have those plans I'd go for something more suited for that.
#75
Engine: 5.7 HSR
starts at post 41
starts at post 41
Yeah they would be replaced with grade 8 for sure.
87, bolt, camaro, connecters, connector, connectors, easiest, firebird, frame, gen, install, installing, jackstands, jegster, nova, subframe
