Jegster Bolt-on subframe connectors
Car: 1987 IROC Z28 Camaro
Transmission: Stock
Axle/Gears: Stock
Are Jegster bolt on subframe connectors easy to install on jack stands? 1987 camaro irocz american thunder full exhaust no cat.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Jegster Bolt-on subframe connectors
When installing ANY SFCs, the car's weight need to be resting on the suspension.
So if you did it on jack stands, 2 would need to be under the rear axle & 2 under the front a-arms, but I don't like the idea of the front a-arms on jactstands. Just strikes me as not good support for being under there.
Maybe the front up on ramps, then the rear on jackstands, but I'm not sure that the chassis wouldn't flex by 1 end being lifted independantly of the other end. Considering that the function of SFCs is to hold the chassis in a certain place, I don't like the idea of flexing the chassis to a different position & locking it in that position, once the SFCs are put in place.
I wouldn't trust ramps seen a few break,If you haven't bought the sfc get a weld on set they are stronger then bolt on or weld in the bolt on ones.I would take it somewhere with a wheel lift and let them put it on.
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
Can they be installed in a flat driveway?
I have limited access to any shops at the time.
Too much work. LOL
I'll save up and get weld-in ones and have a shop install them.
Car: 1988 Iroc-Z Black w/ blue/silver
Engine: L98 5.7
Transmission: 700R4 (obviously)
Axle/Gears: BW 9-bolt 2.77
Im the definition of "bean pole" and i still dont think even i can squeeze my scrawny @ss under a 3rd gen without a jack or jackstands LOL. Thats a tight tight squeeze
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Jegster are super easy to install
im very happy with the fit of the jegsters. you can weld them later. my t-tops used to make noise coming in the driveway. once i installed and welded the SFCs, ive never had a squeek. big diff.
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
You can do it in a driveway on jackstands. They fit well are easy to install, and you can have them welded in later. I am always amazed at the amount of nayusayers on here. It's not a hard job and can be done quite easily....
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
I agree, not very tough to install, bolt in and weld later. Good fitment, I'm very happy with them.
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
Any pics of these subframes installed?? Im in the market for some
Car: 1992 Camaro
Engine: TPI 350ci
Axle/Gears: 3:73
I really like the Jegster SFC. They are easy to install (as mentioned above), fit well along underside of frame rail, give a good jack point/body stiffness and only weigh about 15lbs.
I reccomend welding them in place (which is a cinch)!
Car: '88 Iroc
Not the best pics but I found a couple. The pieces going from the side subframe connectors to the trans tunnel area are pieces I added later.
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Do the Jegster ones fit in conjunction with the Alston inners or do they interfere?
Car: 91 Camaro RS
Engine: 305 TPI conversion.
I bolted in my jegster subframes while my car was on ramps and jackstands. i have yet to weld them but i do check the bolts everynow and then. i also put on a set of topdown solution tubular subframe connector with no interference at all. the car is as asolid as it can be.
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
Car: 92 Camaro RS
Engine: 305 TBI
Hows the driving after putting them on? is it pretty stiff around corners?
All you do is bolt them in on the rear lca munt and swing them up into place on thefront rails/floor pan and support them. You can either drill using the subframe holes as a guide or mark them and swig them back down and drill just make sure you have your carpet pulled back ect....
Car: GTA
Too bad they don't actually connect the subframes since they are not actually even touching EITHER subframe on the car. They are just a still bar that bolts under the car & I question how much they actually stiffen the "frame". I'm sure they help but SUBFRAME CONNECTORS they sure aren't.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
The UMI design is much better with 6 major weld points.
http://www.umiperformance.com/catalo...roducts_id=127
Look down at the bottom of the page and click on the photos.
They cost more than the Jegsters but are far superior in design.
UMI makes excellent products and those are the sub frame connectors I will be installing.
Here's the link to the Jegsters so you can see the difference.
http://www.jegs.com/i/Jegster/550/40053/10002/-1
i have a set of jegster bolt ins in my car. i welded them in and added some extra braces like vortec350s10 did.
here's how i put the car on jackstands whenever i'm doing sfc's...this is InfernalVortex's car from a few years ago when i put spohn sfc's on his car:
Engine: TBI,5.0
The only reason I beleave the UMI has such a good design is that it directly addresses the twisting of the uni body where the problem exist. "vortec350s10"seems to agree with his alterations,and BlackenedBirds comment just enforces that. I am not a racer so I don't know the exact demands on a Third Gen. with a straight launch.
I am simply helping the OP make a educated decision with his purchase. If he has his mind made up already than none of this makes any difference.
Engine: TBI,5.0
Not trying to be a jerk,and it may work but you still could not pay me to clime under a car with the front stands like that, I don't care how many times it been done.The lower control arm is just on the other side of that wheel and is considered a jack point that will accomplish the desired effect.
Nice looking car "InfernalVortex"
i figured i might get someone giving me a hard time about it, as it does look a bit sketchy. it's stable, and keeps the suspension 100% loaded. a drive on lift would obviously be better. the jackstands go under the balljoints now, just for extra piece of mind though.
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I always do the shove test in all four corners when a car is on jackstands. If it passes then I crawl under.
CKone (07-02-2020)
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
I'll like to build ones like this I have the tubing and a Wellder just need the Blueprint of thees connectors do you have anny?
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Thank you for giving Jegs the opportunity to assist you with your technical question.
I have checked, I am sorry, the 40053 sub frame kit does not fit convertible models. Unfortunately, I do not know where to tell you to look from here. If you have any further questions, please feel free to contact us.
Thank you,
Jon Shook
Technical Sales Representative
800-345-4545
ext # 639
Jon.Shook@jegs.com
Thank you,
Jon Shook
800-345-4545
ext # 639
Jon.Shook@jegs.com
Car: 1992 Camaro Z28
Engine: 5.0 TPI
Transmission: auto
wow, i am glad someone told him about that dangerous jack stand placement. I always leave my floor jack under the front crossmember also, and put a little pressure on it for peace of mind. Safety first !
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Q:
Can LCA relocation brackets still be used with SFC's?
1 Post
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
put a strap between those to front jack stands. that'll hold em' in nice and tight. Then your set!
#42
1 Post
I too have the Jegsters. Bolted in and then welded. Love them. Even fit up under the 3" exhaust.
#44
and where do you think all the forces on the rear of the car go exactly? The LCA mount is what is pushed/pulled during acceleration and braking at that exact spot, not the "subframe" back there. IMO the lca mount welded subframe is superior .
#45
Car: GTA
Yes, forces from the tires/LCAs do go through those mounts. But do you really think that the LCA mount is actually stronger than the engineered "frame" of the car?
#46
yes once you weld that thick steel to it I sure do. Not to mention that the subframe is on the same piece of folded over steel if you look at it under the car and a few inches inward. I cut into all that crap when notching my frame for mini tubs and it's stupid thin.
#47
The subframe part is thinner compared with the LCA.
I can also tell that by hitting each with a screw driver's head because the sound is quite different.
Also, in Alston's case, they said the distance between each cup is short compared with the LCA type and that will make it a bit harder to play its role.
But anyway this is just a theory. For now judging from many people's opinions who use them, I think we can say both are effective.
#48
Car: 1971 Camaro
Engine: 427
Any subframe connector is going to benefit a unibody car.
The difference in the design and the related difference in effectiveness is probably so minute you would never even be able to notice.
