Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
solid mounts
Old Sep 17, 2011 | 07:58 PM
youngz's Avatar
Car: 1990 camaro rs
Engine: 305 (L03)
Axle/Gears: 3.42:1
solid mounts
i have a 1990 camaro rs. transmission mount needs to be replaced almost every three months. want to install a solid mount. will it still flex? dont wanna have to buy another tranny. would it be a good idea for the motor mounts as well
Old Sep 17, 2011 | 11:34 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Re: solid mounts
Solid trans mount is generally not a good idea, especially if you have solid motor mounts you can crack the transmission casing. Poly trans mount is the best way.
If you're breaking your trans mount every 3 months, something is wrong that needs correcting.
Old Sep 18, 2011 | 12:21 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: solid mounts
What do your motor mounts look like? Mine were trashed so I installed the poly mounts that way I would hopefully only have to do it once. You can feel it in the cockpit to some degree but that's the way I like it. Some of the guys here are having allot of luck with the "Prothane" brand poly trans. mount. As far as the trans. mount breaking every three months I agree with FireDemonSiC, sounds like there's a problem there and the poly mount might just be a band-aid for a larger issue.
Old Sep 18, 2011 | 06:36 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: solid mounts
You probably have bad motor mounts, and a worn out torque arm mount. Give it all a look....
Old Sep 18, 2011 | 11:12 AM
youngz's Avatar
Car: 1990 camaro rs
Engine: 305 (L03)
Axle/Gears: 3.42:1
Re: solid mounts
didnt think to check the torque arm bushings. looked at the others though. a little soft but not split open yet. how bout solid motor mounts and a poly trans mount with safety interlock to stop it from hitting the floor. jegs has the trans mount for 25.00 i think
Old Sep 18, 2011 | 04:34 PM
youngz's Avatar
Car: 1990 camaro rs
Engine: 305 (L03)
Axle/Gears: 3.42:1
Re: solid mounts
dont mind if i can feel the motor running with the solid mounts. but leave the trans mount poly. and got under it today and torque arm bushings do need replaced. anyone know a company that makes a complete bushing kit for suspension or do i need to piece one together. is there any other reason for the trans mount to break this often.
Old Sep 18, 2011 | 04:51 PM
J91's Avatar
J91
Re: solid mounts
Energy suspension has torque arm mounts, don't know if Prothane does? While you are checking stuff check the rear end mounts, lower control arms, panhard rod. If you are having that much play to break tranny mounts that often I 'd check the drivetrain front to rear. Check your u-joints while you are at it...
Old Sep 18, 2011 | 10:56 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: solid mounts
The stock tranny mount does not hold a good kick down and that stock mount is gone
Old Sep 19, 2011 | 05:07 AM
Engine: TBI,5.0
Re: solid mounts
If you have never swapped out motor mounts your in for a good time. Here's a link I found that may help some = https://www.thirdgen.org/forums/tech...ing-motor.html
Go with the poly motor mounts.Do it once and you should never have to do it again.
PS, I used lock tight on all the bolts,you'll see why.
Here's a link to the poly kits at my favorite place to shop = http://www.summitracing.com/search/Y...?Ns=Rank%7cAsc
Old Sep 20, 2011 | 07:53 PM
youngz's Avatar
Car: 1990 camaro rs
Engine: 305 (L03)
Axle/Gears: 3.42:1
Re: solid mounts
found a complete poly bushing kit for 109 bucks. might just end up sinkin 2000 bucks into the suspension. shes very tired. 220000 miles on mostly factory equip.
Old Sep 20, 2011 | 08:22 PM
J91's Avatar
J91
Re: solid mounts
it'd be a good move on an old car. It will help alot...
Old Sep 20, 2011 | 08:44 PM
-AO-'s Avatar
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
Re: solid mounts
Some poly trans mounts will have the option of using 2 bolts, which will hold the trans in place a little better than the stock mount which has just 1 bolt.
92projectcamaro
Sep 12, 2015 12:33 AM
ynk1121
Sep 12, 2015 12:27 AM
Stryker412
Sep 7, 2015 09:11 AM
FormulasOnly
Sep 6, 2015 10:42 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
