Headlight replacement
Car: 1992 Camaro RS
Engine: 3.1L V6
Transmission: Automatic
Im thinking of changing out my headlights to get them brighter. these are the ones i was thinking of:
1992 camaro headlights
Are these all the supplies i would need? or do i need to buy a regulator of some sort? Or is the whole kit just plug-and-play?
Re: Headlight replacement
You could use that setup just as is but it may cause your headlight switch to overheat. I would suggest doing the headlight upgrade :https://www.thirdgen.org/headlightupgrade
I did what halogen bulbs and the upgrade. It made one hell of a difference. I have other people asking me to do it to their vehicles now. It's simple, fast, and works. Hope that helps.
Car: '83 Z28
or.. if you don't wanna hack the wiring, a set of Silverstars will work. I upgraded the headlights in my Z28 to them and it's worth the $$$ imo.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Unless you have the coin to go with a true HID system (at around $1,000) go with the silverstars.
If you WANT to go HID
http://www.kbcarstuff.com/4656-6-x4-...-p/xd-4656.htm
Axle/Gears: '01 3.42 10 bolt
with the headlight upgrade article linked, what hacking is there????? it plugs in to the factory connectors. no cutting of the factory harness required. i use it and silverstars and love the results.
Car: 1985 IROC Z28
Engine: 355 aluminum heads, comp 294 magnum
Transmission: 700r4 with B&M Mega Shifter
Axle/Gears: Motive 4.10's
What about fog loghts anyone? My car has the factory fogs, do they make an Hid upgrade for these? Like a conversion kit or anything? What about just bulbs? Thank you.
Car: 1992 Camaro RS
Engine: 3.1L V6
So using this setup what would be one way to ensure that the headlight switch wont burn up?
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Those style lights are JUNK JUNK JUNK! Did I mention they are junk?
Don't waste your $. You want simple drop-in? Get the Sylvania Silverstars. Wanna spend a lot more $? Get a true projector HID kit. Lots of money but the output is incredible & worthy it if you can afford it.
Car: 1992 Camaro RS
Engine: 3.1L V6
So the silverstars come in different wattages. which are for high beam and which are for low beam?
Car: GTA
Car: 85 Z28
Just so I'm clear, are the Sylvania Silverstars drop-in replacements or do you need to install relays to avoid overheating the dashboard switch because they draw more power than the standard lights?
Car: GTA
Car: 1991 Camaro RS/1989 Formula
Engine: 5.0 L03 V8
I recommend the Silverstar's. You can pick them up for around 20 a lens at any autozone or o' reilly's and theres no modification necessary. They're a fair price, easy to install and a nice white color light.
Car: 91 and 87 camaro
Engine: 91 360ci and 87 350ci
Transmission: lt1 t56 ,wc t5
Axle/Gears: 3.23 2.42
i been running a set just like that in my 91 since 07 and the only mod was rearrange the wires at the plug and trim the head lights cup and did the same to my 87 3 years ago big differences like 90 better and no issues or any other mods
Car: 87 Iroc
Engine: 350tpi
Axle/Gears: 10 bolt, unsure of gears yet
I finally got my set of lights, from neondaniels. And I love them. Everything works great and they look amazing.
Ghettobird52
Jul 5, 2024 11:18 PM
