Racetronix
Car: 1989 Iroc Z 5.7L
Engine: 5.7L
Axle/Gears: built 4.10s
Racetronix
FYI - Purchased from Racetronix the FL98 / F7 Bulkhead Connector Assembly & FL98 Fuel Pump Kit. The walbro fuel pump looks significantly better then the Chinese fuel pumps that failed on me. Overall it is a great kit, I just did not realize that I had to double check the pump connector(s) with the pump wiring. Both the cable that came with the pump and the new bulkhead connector assembly were wired backwards. See pictures.
Engine: 5.7L
Re: Racetronix
I purchase everything through Hawks Third Gen for $217 delivered. The before and after, it is worth it.
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
Re: Racetronix
I've had this pump in my car for the past two years, great product! Nothing but good things to say about them. When u guys get your smaller issues worked out, u will be very satisfied with its performance.
Car: 87' IROC
Re: Racetronix
My double pumper was $431.
L Item Description Order Ship Price UM Discount Amount
1 FPWH-021 G7 DP Fuel Pump Wiring Harness 1 $100.00 EA $100.00
2 IDPH-G7 Intermediate Double Pump Harness, G7 1 $15.00 EA $15.00
3 DP-ITWH-011 G77 Type In-tank Harness 1 $25.07 EA $25.07
4 HIK-015 G7DPH Harness Installation Kit 1 $10.00 EA $10.00
7 DPC-G7 Double Pump Coupler G7 Billet 1 $27.50 EA $27.50
8 BGK-001-OLD Body Ground Kit 8" 1 $10.00 EA $10.00
9 DPM-001 Dual Pump Mounting Bracket GSS340M / G77 1 $25.20 EA $25.20
10 GSS340M 255L/Hr Fuel Pump - High Pressure 2 $89.00 EA $178.00
11 FFS-122A Filter Sock, 104x42mm 22mm ID, G-D 2 $3.00 EA $6.00
12 FSRR-G7 Retainer, Locking Ring, G7 Stainless 1 $3.99 EA $3.99
13 FSG-G7 Gasket, G7 Fuel Sender, Spine/Molded 1 $4.99 EA $4.99
16 SH SHIPPING/HANDLING 1 $25.64 EA $25.64
Car: 1991 Z28
Engine: 383 TPI
Transmission: 700R4 w/2800 stall
Re: Racetronix
My Racetronix kit had the wrong plug on it too, I let them know, they sent me the tool to remove the pins from the plug and the correct plug. Easy fix.
Car: 87' IROC
Re: Racetronix
Cool. I have been fiddling with this thing trying to figure out how the release mechanism works for the pins. Since you have done this, can you provide a picture of the tool or explain how the pins release? Normally you can look inside the connector but this one is a bit more hidden.
Car: 1991 Z28
Engine: 383 TPI
Re: Racetronix
The tool was like a very small screwdriver with a small diameter hollow shaft that basically went around the pin and contracted the tab that locked it in the plug. I'll try to send the photo tonight, but you'll be supprized how simple it is.
1 Post
Car: 91 Z28
Engine: 6.0 LSX Single turbo
Transmission: 4l80E
Axle/Gears: Moser 9" 3.55
Re: Racetronix
I know this thread is ancient, but how did you get the pumps into the tank as you have it assembled there? The tank opening is smaller than the size of the pumps.
