Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Wizard Cooling 2 row Alum rad
Old Apr 26, 2013 | 07:25 PM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
Just got a sweet deal on this rad and wanted to show it off plus provide a little feedback about it.
So it lists for $450 and I got it for $250 at the carlise pa swap meet/show right from the wizard cooling truck!!
I almost didn't get it but it looked like such a quality piece I couldn't pass it up. So it has 2 rows of 1" tubes fully tig welded construction with a billet filler neck and probably weighs 15lbs-20lbs. It got heavy carrying it back to my truck!! Here are some pics to judge for yourself. I will follow up after I install it.
Old Apr 26, 2013 | 07:56 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Wizard Cooling 2 row Alum rad
What are you waiting for?!!? LOL!!
Looking forward for the review...
( edit )
What external trans cooler will you use?
Old Apr 26, 2013 | 08:01 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
also interested . ............
Old Apr 26, 2013 | 08:17 PM
seiplentz's Avatar
Car: 85 Z28
( edit )
Hah! I will hopefully have it in on sunday to at least test fit it.
I already use an external cooler for the trans. Not sure of the brand but its big. I think it was one meant for a truck that does a lot of towing.
Old Apr 26, 2013 | 08:39 PM
Car: '87 Camaro
Stock fan(s)?
Sorry for all the Qs......
I'll be rad shopping in about a month.
Good luck
Old Apr 26, 2013 | 08:55 PM
seiplentz's Avatar
Car: 85 Z28
Stock fan(s)?
Good luck
No I am not running stocks fans. I have 2 12" hayden fans. I will be working on a mounting solution for them.
Old Apr 28, 2013 | 03:04 PM
seiplentz's Avatar
Car: 85 Z28
Ok so this thing is massive as compared to the stock rad. It appears there will be some modding to make it fit just right. The guy who I purchased it from said they changed their mounting tabs on the top for a better fit which is why I got such a good deal on this one. I dont mind adjusting it probably would have to do it anyway.
So for a test fit I had to cut the rubber on the bottom and I dont know what I am going to do for the top yet the bracket is about an inch off from getting the bolts in. I could cut the condenser pads and bring it closer there.
Old Jul 5, 2013 | 04:04 PM
seiplentz's Avatar
Car: 85 Z28
So I finally got this installed and it fit pretty well. I had to remove the oem rubber from the bottom and use a piece of tire tube to insulate it. at the top I had to trim the condenser bump stops to bring it closer to the rad support. After that it fit great. Used the stock rad mount.
I also installed an 98-02 fan setup which required me cut the lower rad support so the fans would drop all the way down. And for the top I just used a piece of steel to hook the top.
So far on a 95 degree day here with only water in it the temp just went to 190 while in some top and go.
Old Jul 6, 2013 | 11:17 AM
gsmarcano's Avatar
Car: Camaro
Engine: 350-Vortec-carbed
Transmission: 700-r4
Axle/Gears: stockola, right now anyhow
looks good, I've got to do something like this too.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
randy210
Oct 15, 2015 03:43 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ndndndnd
Sep 28, 2015 08:00 AM
