T-Top Weatherstrip/Door Gaskets
Car: 1983 Trans Am
Axle/Gears: Stock
Getting my car painted, what the best T-top weather striping to buy and the easy to install, were can I purchase a set. Just don`t want to purchase
a cheap set. Any info is please.
Al
1983 TransAm
Al
1983 TransAm
Re: T-Top Weatherstrip/Door Gaskets
None of it is easy to install. It takes some effort to get it right. If you do a search you will get a range of opinions. My best recommendation is to stay away from OER. It is junk. I used Soffseal for the t tops and was happy with them.
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
2x for Soffseal.
Avalible from any of your favorite resto shops.
Year One
Classic Insudstries
etc
Year One
Classic Insudstries
etc
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
GM Parts Direct had the best price on original seals for me, but that was a few years ago.
Car: 1983 Trans Am
Axle/Gears: Stock
Thanks for all the help, so the best place to purchase them would be GM Parts Direct
or Classic.
or Classic.
Car: 1971 Camaro
Engine: 427
Or Year One, or Ricks Camaro, or.... etc... Heck, I think Hawks has them too.
I actually got mine from Autozone.
Only complaint about Classic Industries is their shipping rates are high. I did see they were offering free shipping for Black friday though.
Car: 1988 iroc-z
Engine: 350 5.7L Tpi
Transmission: 700R-4
I am trying to replace my t-top outer seals..the ones that the door window glass goes up against when rolled up..ive seen various aftermarket ones online for about 50 bucks free shipping...i see hawks had them for 69 bucks plus shipping..do u think its worth the extra money thru hawks? is it a better product than 1aauto or other companies? I cant find any original gm part so aftermarket is my only option i believe? Thanks for the help
3x soffseal
They made the original weatherstripping for our cars. A little differently made now though, no plastic reinforcement on the ends for door and seal around it. Don't skimp where it counts.
On Probation
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
http://www.lonestarcarparts.com/
This place sells Softseal @ the CHEAPEST price I could find.And I have had it on my car since 2006 with no leaks !!!
DO NOT GET METRO or anything from 1aauto,have heard TONS of complaints !!!!!! Classic industries is a RIPOFF !!!
Dave
Dave
[quote=3rdgenparts;5685413]http://www.lonestarcarparts.com/
This place sells Softseal @ the CHEAPEST price I could find"
1982-1992 Camaro / FIrebird Hardtop Complete Weatherstrip... (190812182899)
Member id lonestarcarparts | Feedback Score Of 35887 | 99.9%
Sale date: 03/22/13
$255.00
+ $21.50shipping
Sale date: 03/22/13
$255.00
+ $21.50shipping
I bought the t top drip edge from 1A. Not sure who makes it as there was no brand name on it. But I suspect they all sell the same one made by the same company as they all look the same. There are 2 versions - rubber and plastic. I really liked the look of the rubber, but I did not have any luck getting the double faced tape on the edge to seal to the t top. It kept pulling away from the t top, and I suspect that it was due to the way it was molded. I called up 1A and told them I was not happy with them and they replaced them with the plastic version. They fit well, and I am happy with them.
1 Post
Car: 1990 Camaro RS
Engine: 5.0L
Transmission: WC T5 5-speed
I got mine from Steel Rubber Products in Denver NC.
Steele Rubber Products
Excellent products and customer service.
Car: 1988 iroc-z
Outer drip seals ..and i already ordered them through hawks the rubber syle..nine are rubber style so goin with original ..hope they work out
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
If you have any experience with dealing with weatherstripping, may I suggest you put it on rather than the body shop. I had a bad experience trusting my body shop with any weatherstripping. I got all new rubber and they installed it poorly. It leaked, when I weant to remove and diagnose, it stuck to the paint. then I noticed that the center bar was supposed to have a rubber cushion. Guess what they painted over it. Now for the doors. They left the drivers door window wobbly, why b/c they screwed up the outer door seals and ran oversized screws to secure it. Ended up using all my old weather stripping. So if you can do it, put it on yourself. That's my two sense.
Car: 1983 Trans Am
Axle/Gears: Stock
I picked up a full set of soft seal. I will reinstalling everything myself as
soon as I get it back from the body shop. I purchased a new black t bar
from Hawks hope it goes good I did loose a few screws.
Thanks for the info guys.
Al
Al
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Should do them in a heated Garage or wait till the weather breaks.
Car: 1983 Trans Am
Axle/Gears: Stock
Install them in a heated garage or on a hot day. Will make it easier to mold to the top.
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i bought my kit from lonestar years ago because it was suppose to be softseal. I left the package closed for like 4 years. Well had the car painted and opened the box to find this garbage metro seals. They fit like ***. T-Top has a huge gap where the a-pillar is. door seals are worse as the doors wont close now. I adjusted the doors as best as i could but still wont close. The old door gaskets were better then this crap
Car: 1984 Camaro Z28 H.O.
Engine: 5.0. L69
Transmission: Automatic
Axle/Gears: 9 bolt disc 3.27 Posi
I replaced all of the rubber including the t-top seals, it took two days with some help from a friend. I never did it before but if you take your time it's not that bad. The hardest part was the rubber at the top of the door. You have to take the door panels off and make some adjustments. I got all from from Classic Industries.
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
I used GM for the t-tops, and Softseal for the doors. Both have been good so far.
Do your prep right, and install properly, and all should be good.
Alicat.
Alicat.
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
Thanks in advance!
Former Sponsor
Sorry to do some necro-posting here, but anyone knows which cars came with plastic and which with the rubber drip edge seals? I noticed Hawks also has both and they tell you to go with whatever you car has originally. I'm wondering what the reason for different ones might be and if one variant has advantages over the other?
Thanks in advance!
Thanks in advance!
We offer free shipping and a lifetime warranty on them too. Here's a link to them on our website. Camaro Drip Edge Seal
Tony
Axle/Gears: 10 Bolt 2.73 Open
I think the plastic is for the later years of production...91-92 perhaps. I know my '88 came with rubber when new.
Engine: LS1 / L03
Does the later plastic version then have any advantages as to seal or durability over the years (decades) or was it just a cost driven decision at GM?
I started installing soffseal on my 87 IROC and so far I am very happy with the results. I have it installed on the passenger side and it is soft and seals well with out giving the window any issues when rolling it up. After I put a little STP on the weather stripping. It is a little dry out of the package. Looks just like the factory IMO. I have the OER brand on my second gen ttop and that stuff is stiff and has no give to it. It is so bad that the windows will not roll up all of the way. I will be changing that over to soffseal possibly this winter.
1Aauto
Sponsored Vendors
01-15-2016 06:26 AM
Thirdgen89GTA
11-26-2015 11:04 PM
92, camaro, gasket, gen, plastic, replacement, rubber, seal, sof, thirdgen, top, v8, version, weatherstrip, weatherstriping
