Does this block look pitted?
Car: 91 Camaro RS
Local machine shop is selling this block... Looking at the photos, it looks as if the area around the water jackets are pitted. Am I being to skeptical?
Car: 91 Camaro RS
Re: Does this block look pitted?
Yeah, that's what I was thinking! I sent him an email earlier to voice my concerns... his reply:
"It has been decked. Their may be some discoloration around coolant holes, but I think you can see it has been decked."
Is it possible it is too deep? The block otherwise looks good; nice parts: KB pistons, Scat crank,... For 850 - is that a decent price? Or should I walk away with the obvious corrosion?
Car: 1982 Pontiac Trans-AM
Engine: 283
Transmission: Saginaw 4 Speed
Do you feel that slight corrosion will make the head gasket fail?
Car: 91 Camaro RS
Engine: 283
I don't think that the pitting around the water jacket would make the gasket fail. I'd go with it, but it's a gamble.
Car: 91 Camaro RS
Yeah, thanks. 850 is borderline what I want to pay for a gamble.. It is local, but I am contemplating a crate engine as well
that block is fine , it looks just like every other used chevy block out there
u guys worry way to much about stuff that dont matter
Engine: 283
Electrolosis happens; as long as there's enough flat metal around to seal well, I wouldn't be too worried if I bought it.
Car: 91 Camaro RS
Perhaps I do worry to much... Just trying to be cautious; buying an engine from someone I do not know. I wish I trusted people to sell good products, but I do not.
a reputable shop wont risk selling something that is iffy
Car: 91 Camaro RS
That's the thing... I found the listing on ebay; they are local though. I can not find anything about them really.
$850 is not a bad deal. its just a close to stock eng. (not a ricky racer)
have paid more for less and beat on it for over 10 years..
grab it.. and use it. use felpro head gaskets printo seal (i think they are called) about $35 ea and you will be fine..
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Looks typical for a machined surface that has been sitting on the shelf collecting some moisture.
Car: 1971 Camaro
Engine: 427
Are they calling it "zero decked"?
How much has it been bored?
What about the compression?
You're gonna have to run some big chamber heads with thos pistons if you want to run on pump gas.
Its a 2 piece ream main block as well, which means flat tappet or retro roller cam.
Personally I don't bother building with these old blocks anymore.
Car: 91 Camaro RS
Yeah, I just do not like the sellers attitude (really short with me and does not like to be bothered with my questions and that is probably why it is rusting), nor does the block look like it has been thoroughly went over. I have decided to spend the extra cash and bought a brand new chevy performance 350 .
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
I'd run it with a .039 gasket without any concern. Even a shim prepped correctly would be fine.
-- Joe
I don't know about the pistons. To me they look like they have huge valve reliefs. Without the part # who knows.
I dunno. Price is probably fair if it's what he wants.
Is it even a 4bolt main?
-- Joe
Linson
10-01-2015 09:50 PM
