what exactly does the lower control arm relocation brackes do? and do they help.
Take form Spohn's web site;
Repositions your instant center by lowering your control arm angle for increased traction and anti-squat. Lowers rear of control arm up to 3".
This product is a must for lowered vehicles to correct your suspension geometry. Lowering your vehicle alters the LCA angle putting the rear of the LCA higher than the front of the LCA, this causes massive wheel hop and traction loss.
NON-LOWERED vehicles will also see a dramatic increase in traction by lowering the rearward angle of the LCA with our relocation brackets. The lower mount holes are placed in the arc pattern of the OEM length LCA. Therefore allowing a non-lowered F-Body to drop the rear LCA angle and NOT require a longer than OEM LCA. All geometry is correctly maintained. The anti-squat performance is providing most users with a full .10 or better 60' reduction!
My car is lowered and these were the best suspension mod I did besides the adjustable torque arm.
i don't get it, i added kenny brown lca's.......my car is 2 in the front and 1.5 in the rear and i have no wheel hop problems.
granted i'm only around 375 though.
My car is lowered 1",and I too didn't get any wheel hop.Just MASSIVE wheel spin.
that's my point.........even under a good amount of horsepower....my car only spins, no wheel hop after the mod.
if someone could please explain why i might need the relocation brackets i too would be happy to add it to the list.
my car is at stock height, but my gear is 2.73's, if i change to a lower gear and relocate my lower control arms should this take care of the wheel hop?
my good *** man.......... a lower gear than 2.73?
i lowered my car with the eibach pro-kit added some nice tubular lca's, aphr, sbfc's and i'm running a 3.23 with little over 300 out of the hole and have no wheel hop...........just spin. but it's expected with street tires.
I had a 3.42 complete disc rear and let it go. I didnt have time to swap it and and the rear clip it was under was being picked up. I wish I could have kept the 3.42's. but at least my 2.73's have posi. Im thinking of going with 3.73.
Quote:
Umm... yeah, what's wrong with that?Originally posted by Kandied91z
well if your talking lower like 2.72 and lower....... hey, whatever works for you.
2.72 gears (if such a thing existed) aren't lower than 2.73 gears. The numerically larger the number, the lower the gear.
you mean they don't make 2.72 gears???
:hail:
you obviously missed the point, but it's alright.
:hail:
glad you posted in my behalf. I guess some guys dont understand that numerical higher the gear the lower it realy is.
Thats why most people around here call 2.73's airplane gears.
which would be fine out on the salt flats but realy sucks on 60 ft times:lala:
:lala: this little dude looks like a marshmellow on crack
or a ***** huffing NOS!!! ha! ha!
