Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
I want to get these heads
Old 03-08-2001, 02:02 PM
Blade's Avatar
http://cgi.ebay.com/ebaymotors/aw-cg...248520&r=0&t=0
There's a set of Trick Flow 23 degree heads on ebay for sale for 800 bucks with everything on them. Would these be okay, or should I save up for the AFR 190s ? I really want a set of aftermarket heads, because I feel I cant get any faster with my current setup.
92 Z28 5.7
Ported stock heads, XR270HR-10 cam, TES headers
Crane AFPR, Flowmaster catback, MSD ignition
#24 SVO injectors, 1LE aluminum driveshaft.
Best ET 13.3@107 mph
Click here to see my car at Truspeed.org
Check out Truspeed
Check out the Bin Archive
Old 03-08-2001, 08:20 PM
The ODB's Avatar
I like them.
Old 03-09-2001, 10:11 AM
Blade's Avatar
Think the cam I got in there now should be alright ? Traxxion runs the same cam with his AFR190s and pulls low 12's (with a miniram too).
Old 03-09-2001, 11:20 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Everything that I have read about the 23* Trickflows indicate they are an excellent bang for the buck.
Yes, the AFR will flow more but is the extra flow worth it to you? If you had a MiniRam, I would be inclined to go with the AFRs as they can take full advantage of the flow.
Old 03-09-2001, 07:58 PM
mtg92camarors's Avatar
This really is the wrong forum for this......
Old 03-09-2001, 10:40 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Blayd,
I don't have the same cam. Mine is on a 112LSA.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old 03-10-2001, 12:20 AM
Blade's Avatar
Except the LSA IT is the same cam... I dont think the LSA play that much of a role compared to the other specs of the cam.
Old 03-10-2001, 01:23 AM
Dan87IROC-Z's Avatar
Yes, the LSA isn't as important as the duration and lift, but don't discout it totally, it is critical in figuring how a cam will run in a car. If you haven't read the cam article in the tech section of this site, it explains the way the LSA effects performance.
But I do agree with Glenn, the Trick Flow Heads offer a great bang for the buck. Yes, they aren't as good as the AFRs, but for $800, they sure make your wallet much happier!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Hotrodboba400
12-10-2019 07:07 PM
92projectcamaro
01-18-2016 08:00 AM
FormulasOnly
09-06-2015 10:42 AM
z28guy134
09-01-2015 11:50 PM
Quick Reply: I want to get these heads
