PCMforless Thumbs up!
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Got the custom chip yesterday, put it in last night and test drove it this morning. I am very happy, no more surging at part throttle and definitely feels like it has more power at part throttle midrange, Feels great at WOT! Not to mention they got the chip to me in 6 days! (I did pay for the 2 day shipping)
Amazing service on a great product!
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
Re: PCMforless Thumbs up!
They did a great job on my 88's chip years ago.
Engine: gone
Transmission: gone
Axle/Gears: gone
hey way to go. I hope to get into custom tuning but ya never know may need a chip source. any chance to tell us what you paid? and was it a 100% custom chip or was it more of a preset chip?
Car: 1992 Camaro B4C
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
Was this a regular v8 chip for the thirdgen...I am in need help for my custom chip I'm having a damn lagging on my rpms and midrange...all this after installing the headers. I was wondering of thats what you guys had...?? Also which chip did u get bcuz they are not very discriptive..I have a 92 Camaro L98 TPI...and need help soon I ran it in the quarter mile and was slower by .56 after installing headers and deleting all smog stuff...
Engine: gone
Transmission: gone
Axle/Gears: gone
I went to thier website they have 3 options. stock, heads/cam, and some other option.
They also do not offer anything for TBI cars. So TBI guys still have to use tbichips or dynamicefi.com for self tuning.
Just went to the website, and I have a question about buying a stock one. How much power can you really gain? or what can I expect? Is it worth the 150$ asking price?
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
i live 100 miles from pcmforless... they tuned my car... very good people... alvin is the guy that tunes tpi cars..... I will be going to him again shortly after my FIRST intake swap....
1 Post
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
PCMforless set me up with a custom chip last year and the car ran great, no complaints at all. Then I added headers and Y pipe and eliminated all of the emissions crap and my mileage got kind of poor and I had a CEL on. When I went to Florida at the beginning of March this year I took the GTA with me and stopped in at PCMforless on the way down for a retune, pulled out my ECM from under the dash and half hour later I was popping it back in the dash and on my way. My mileage went from 19-20 MPG to 22-23 MPG and it gained alot more power in the mid and upper range. Very satisfied with them and I plan to use them for a long time, especially now that they are associated with big shot dyno which is only 1.5 hours from me by Summit Racing.
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
That is great because that's what happened with me I installed my headers and exhaust and belted all my smog stuff n I lost power and mpg. NOw I'm wondering which chip did u get or was it all custom?
1 Post
Engine: 355
Transmission: 4L60
It will gain you as much or more than a hypertech chip and it's cheaper, so those are 2 pluses. I'd say you'll gain about 10-15 HP roughly on a dead stock car.
1 Post
Engine: 355
Transmission: 4L60
I just checked the website and I don't remember them having 3 chip options when I ordered, but I'd guess I just have a stock/bolt-on chip as it is classified by them now. You just tell them all the mods you have when you go to order the chip (a form will pop up with all the options as your ordering) and they'll make it custom for you and anytime you make a major change they will reburn it for you for $50 bucks.
100% custom, You fill out this order sheet, a total break down of your combo.
http://www.pcmforless.com/index.php?...id=2&Itemid=43
After you fill out and submit that you pay for the chip, there are 3 options
Stock/bolt on $144
Heads/cam $189
Stroker $209
I got a heads/cam chip and paid for the 2 day shipping, that was like 24 buck so I basically paid $214
Stock/bolt on $144
Heads/cam $189
Stroker $209
You lost MPG because you need to go to a heater O2 sensor when you go to headers to maintain the gas mileage. headers dissipate heat much better than the log/cast iron manifold's so the 1 wire oxygen sensor doesn't stay heated up. As for power loss, if you pulled your smog stuff and are throwing a check engine light you aren't probably aren't in closed loop again hurting mileage and power.
1 Post
Engine: 355
Transmission: 4L60
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
My 02 sensor is right on the collector of the headers on the top middle. Well and on the loss of power its like I did throw a check engine light and it sucks bcuz I ran a 15.02 stock and then installed headers and 3" exhaust and now ran 15.56. I was wondering what you guys think is it the chip I need to help a little or is it the open loop that's hurting..if possible can you explain the open closed loop as I'm new at upgrading problems. Thanks
1 Post
Engine: 355
Transmission: 4L60
Open loop is when the computer basically reads from a bunch of set, non-changing parameters. It should only be in open loop when cold or when under WOT I believe. In closed loop it takes readings from all of the sensors and make changes as necessary to make it run optimally.
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
Well I just purchased my pcm chip and had all my custom things there so hopefully that helps me with all that and thanks for the help guys.
Number 1 thing is, what code is it throwing?
If you are just throwing codes from having the emission's equipment removed, the chip should take care of that (if you put that in your order sheet) just make sure everything else is up to par and you will be happy with the new chip.
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
Sorry I don't have anything to check for codes but yea in a explaination its just that my car with not pull as hard as it use too and it will chirp n and out power in my first gear.. but would the chip help any with the lagging of power or with the loop....
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
Hey guys installed the PCMforless chip today and my car is a whole other car now. It pulls hard and its awesome. But i know this isnt the thread to talk about it but the topic was already started. With out checking the codes would anyone be able to tell me what it is. The check engine light is on for most part of the time. There is time in the morning where the check engine light goes off or when i go full throttle were the light goes off. I know we were talking about a heater o2 sensor do you have a part number or do i use one from another year camaro. Thanks
Unless you can find some one who can telepathically communicate with the ECM and get it to tell them the Trouble Code, no you will either have to scan the ECM or jump the A-B port and have the SES light flash the code out for you.
Car: 1991 trans am
Engine: 396 tpi,afr heads,roller comp cam
I got the same thing after i installed my pcmforless chip, it also stay on all the time except full throttle,but they did a great job.I got a 396 sb chevy from jegs and with tpi it didn't hardly run until I put in their chip and now it ran a 11.46 i agree they are great.
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
Okay when switching to the heated o2 sensor is there any adapters or would it just plug in? & jlackey4 were you able to fix that problem if so how.
I used this connector and wired it up myself.
http://cgi.ebay.com/ebaymotors/MSD-8...d=237096807445
if you don't want to cut the 1 wire connector off the harness you can use this to connect to it.
http://cgi.ebay.com/ebaymotors/Weath...Q5fCarQ5fParts
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
great guys, had a chip burned for my 89 firebird bolt on L-98 and man I can tell you the car idles 100% better and seems to really keeps pulling after first gear which it used to fall on is face now just keep going.
ramicio
09-06-2015 11:25 AM
Linson
08-21-2015 02:12 PM
