Beware of this fraudster.
Car: 1984 Trans Am
Engine: H.O.
To any 1982-1986 Firebird owner with a headlight motor that needs rebuilding, "CharlesRUS" has an eBay listing claiming he can rebuild your headlight motor for $84.98. This is a RIPOFF. I lost $84.98 to this fraudster. Don't throw your money away. If you require a rebuild on your headlight motor, here is a link to an honest rebuilder. He can also install an optional metal gear in place of the factory plastic for a significantly longer lifespan. The link is:
https://www.ebay.com/itm/15446019674...3Avlp_homepage
If you're trying to find a new motor somewhere out there on the WWW, good luck. I searched for hours and found nothing.
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Beware of this fraudster.
Thanks for the information...
Car: 82 Corvette - CFI
Engine: 383 - Renegade, AFR 195, Bullet cam
Transmission: 700R4 - 3,200 Yank TC
Axle/Gears: 3.31
Car: 1984 Trans Am
Engine: H.O.
Just trying to prevent other members from getting screwed by the same ******* who took me for almost $200.
Transmission: Pro-built 700R4
Why would anyone pay that much to repair those? They are super easy to fix. Get the kit from Lon and basic socket set. Shouldn't take more than a half hour start to finish.
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Don't even need a kit. Fill the center of the gear w/epoxy, put it back together...run the wee out of it.
dirtbag
Jun 19, 2003 04:51 PM
