Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Vacuum Lines For HSR
Old May 22, 2005 | 08:45 PM
klumb15's Avatar
I'm tryin to figure out the mess off vaccum lines on my car...i had TPI, now I have HSR...the HSR has 4 fittings on the back, 2 small, 2 big...i have a sensor that fits into the bigger one, then i'm guessing the other big one is for a fitting for the brake booster am I correct? then we got the 2 small ones...i deleted all the smog, and charcoal canister, and I was thinking what else needs vacuum? The only thing i could think of is the brake booster..what are the other fittings for? do i just put plugs in them??
Old May 22, 2005 | 09:03 PM
rsn932's Avatar
fuel pressure regulator needs one.
also there is one that is bigger than all those small little vacuum lines on the TPI but smaller than the brake booster line, i forget what it goes to, maybe HVAC?
dont forget about the opening on the bottom of the HSR plenum. I have my PCV going there.
Old May 22, 2005 | 09:12 PM
klumb15's Avatar
i bought a filter for my PCV hole in the valve covers....I just figured I didn't need it....I don't think I need it do I, it won't F the computer up or anythign will it??
so the 2 big ones on the back are HVAC and Brake Booster right?
then the one underneath I can just plug right?
Then one of the little ones is fuel pressure regulator..whats the other one for?
Old May 23, 2005 | 08:42 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Might not be a bad idea to hook one of them up to the MAP sensor, if you have that.
Also, your HVAC system will do a better job of directing the air flow (like, it'll come out of somewhere besides the defroster ducts when you want it to) if you hook that line up.
NO, you don't "need" PCV; if you don't mind your oil getting contaminated with all the stuff that PCV draws out of it; and you don't mind your valve covers always having oil puked all over them by those stupid breathers; and you don't mind your car smelling like cars from the 50s always smelled (like burning oil and exhaust). If it's a strip-only car, that's one thing; but if you drive it on the street, you'd be well advised to hook the PCV up properly.
Old May 23, 2005 | 03:23 PM
klumb15's Avatar
hmm...so all I do is just get like a 45 degree fitting for the hole under the plenum, then i just run a hose to a pcv valve right??
also am I right on all the other holes?
Old May 23, 2005 | 03:25 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
MAF or S/D?
Old May 23, 2005 | 04:14 PM
klumb15's Avatar
its MAF...if somebody knows, can you just list what ever hole does, and tell me if I need it or not....like i said I deleted all smog and ac if that matters..
Old May 23, 2005 | 04:28 PM
rsn932's Avatar
Ok mine with a MAF:
intake air temperature sensor (IAT)
brake booster
HVAC
PCV
I put the PCV on the bottom of the plenum for more even distribution(in the middle). The other 4 are on the back.
edit: The IAT and the brake booster are the 2 big ones. the FPR and HVAC are the small ones on the back.
Old May 23, 2005 | 05:45 PM
klumb15's Avatar
ok thats what i needed...thanks alot...i just need an answer for the PCV...is that all i do is just put a 45 fittin on there and just run a piece of hose to a PCV valve in one of the vavle covers?
Old May 23, 2005 | 08:26 PM
rsn932's Avatar
sounds good to me
Old May 23, 2005 | 10:58 PM
RedIrocZ-28's Avatar
Car: Iroc-Z
Engine: 355 AFR'd HSR
I'd recommend a 90* not a 45*
Old May 23, 2005 | 11:02 PM
rsn932's Avatar
good point. the 45* works fine, so if you already have one dont worry. the 90* will just make it all a little easier. either one will get the job done.
Old May 24, 2005 | 06:11 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If you have a MAF, make sure you hook the other valve cover up to the place that is supposed to supply clean air to it (NOT one of those stupid breathers) because if unmetered air is allowed into the intake tract by the PCV without having passed through the MAF, you WILL have idle problems.
The factory arrangemenet picks up the air for the supply side of the PCV system from the throttle body, in front of the blades, where it will have already passed through the MAF in order to get there; and the PCV valve also hooks to the throttle body, right behind the throttle blades. Anywhere on the plenum would accomplish the same thing for that hookup. Makes the PCV system, including the crankcase, look sort of like a small throttle bypass; containing entirely MAF-measured air.
gta892000
Aug 11, 2019 11:16 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
