Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
when do i need a bigger throttle body?
Old Jul 17, 2005 | 10:03 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
would i see any increase from a bigger throttle body yet? according to my mods?
Old Jul 18, 2005 | 12:05 AM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
I don't think you would if you did it would be small. stock TB flows 650cfm I think some one said its good up to 400hp but I could be wrong
Old Jul 18, 2005 | 11:14 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
From what I've read and learned, data log a wide open throttle run. If you're not getting 95-100 KPa readings at WOT I beleive that means there is still vacuum and a larger TB can be useful. Otherwise, stick with what you've got. Kinda makes sense, but I've not done the testing with different sized TB's to verify this...
Old Jul 18, 2005 | 01:43 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Basically, what Vern said.
If your getting 95-100kpa readings at WOT u dont have a restriction that is hurting you.
Bigger TB's have more effect than just pure airflow under WOT conditions, there is also more air at all throttle openings and this will have an effect on VE as well as AE.
later
Jeremy
Old Jul 18, 2005 | 11:36 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
thanks
Old Jul 19, 2005 | 12:15 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
A better comparison (more universal) would be WOT 3000 RPM vs WOT 5000 RPM MAP values. a 3 kPa drop there would be acceptable. Might want to compare with and without an air filter there too, just to get some more data.
Old Jul 20, 2005 | 04:22 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
guys not for nothing but i have a hsr and bbk 58mm tb. i had the stock tb on it and the guy who does my tune (yes mail order thru datalogging ) he says that the bigger tb shouldnt have any effect on the tune. is this true.
Old Jul 22, 2005 | 06:55 AM
smokefan's Avatar
another thing with the bbk 58mm, after i installed it the car is starting to pop thru the intake. is this from running the bigger tb with all the mods that i have done and not changing anything in the bin
Old Jul 22, 2005 | 08:13 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
yes. its true. the ECM is measuring the amount of air going in. it doesnt look it up by TPS
the only thing that MAY be effected is the "pump shot" that is made from a lookup table based on TPS change.. but short of going from stock to a HUGE monoblade or anything of that nature, it probly should not be changed.
if it was running fine beforehand, its more likely that something else besids the bin is to blame
Old Jul 22, 2005 | 08:26 AM
3.8TransAM's Avatar
Bigger TB's have a direct effect on AE fueling and some on the VE.
A lot more air moves into the TB when the size is increased and this can and does make for needed changes in the bin to accoutn for this, if one wants to do it the right way.
Ask people who switched from a TPI to a Stealthram and do their own tuning, they all needed to add AE. Lot less runner equaled a lot more air sooner.
This is a example of what I mean and it is extreme when comparing different intake setups.
The same premise holds true when just using throttle bodies to do the same thing, just on a smaller scale obvioulsy.
Use a wideband and do some testing and it shows up quite easily.
The 48 to 52 mm swap isnt the one that causes the bigger concerns either(usually a waste of $$ on a asotck motor), its usually when someone goes from 48 to 58 they see more issues.
Twin 48 should be fine thru the 400hp range or so and head for the 52 after that. Serious combos need the dual 58 or mono TB's in my own opinion.
I'm sure someone will argue or start a flame, again, I dont care, just passing on what I have learned and observed firsthand
later
Jeremy
Old Jul 22, 2005 | 09:32 AM
vernw's Avatar
Old Jul 22, 2005 | 09:55 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
throttlebodies only have that effect when they become the primary restriction of the intake tract.
normally, the intake and heads are the primary restrictions...
true, if you put a steathram on a high hp car,
tune it for the steathram with the tiny stocker TB
then put a huge one on so theres zero restriction
then, it will effect VE.
but thats because you changed the restriction
Old Jul 22, 2005 | 11:39 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
IAC following issues also are apparent and will need to be adjusted. Some surge, off idle leaning, and stalling could also work into the mix because of the IAC reactions. Its all part of the game
You will most definatly need to tweak the AE to account for the increased air from the old settings. A 52 replacing a 48 may not need much but could be changed to make everything nice, but from 48 to 58 will need some work done.
I'll be knee deep into these issues here shortly. I only went 52mm to keep myself sane while my combo keeps increasing.
Old Jul 25, 2005 | 01:46 PM
RedIrocZ-28's Avatar
Car: Iroc-Z
Engine: 355 AFR'd HSR
Someone want to email me what part of the AE to change when going to a HSR and a bigger TB? Make it short and sweet, I should be able to take it from there. Also, is a WB needed to accurately do this?
tcarlson41@comcast.net
-Brad
Old Jul 25, 2005 | 04:49 PM
JP86SS's Avatar
Good info
From the PROM Burning Guide
https://www.thirdgen.org/techbb2/sho...hreadid=195745
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
Thornburg
Aug 27, 2015 08:33 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
