Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Will this get me in the low 8's (1/8th mile)?
Old Jul 21, 2005 | 12:22 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
1988 Irocz L98
Stock heads have been fully ported gasket matched to Felpro 1205, 3 angle valve job.
Milled to lower the cc to 60cc. FelPro copper head gaskets .039" thickness
1.6 roller tip rockers
stock cam
Holley Stealth Ram intake ported and gasket matched to FelPro 1205
52mm TB, with coolent bypass
Ram air airbox mod with K&N's Ported MAF
Headmen shorty headers, y pipe, Catco cat 3" cat back with Dyno max muffler.
MSD Coil, cap, wires
LS1 28.5lb injectors
Smog pump delete
Custom chip
TH700r4
9 bolt rear with 3.27 gears
26x11.50x17 MT Et Streets
Rear LCA drop brackets, Lackwood ca, poly ta bushing, remove front sway bar.
Fiberglass hood, sound deadner removed, rear seats gone, battery in hatch.
What will it run? Any guesses?
When I got the car, all stock, with 2.73' open rear, and no tune up ever it looked like, the car ran 15.5 in the 1/4.
Old Jul 22, 2005 | 12:07 PM
Car: 1971 Camaro
Engine: 427
any guesses??
Old Jul 22, 2005 | 02:33 PM
brutalform's Avatar
I dont think so, with the "stock" cam, and the #28 injectors. When you say "custom' prom, is that an eprom you will be tuning yourself, or one that will be purchased through mail order? Youll be throwing away your money with the mail order proms. Anyway that still is too much injector IMO.
With #24 injectors, a better cam, and a good tune, along with a 2600 to 2800 stall converter, I think you might accomplish your low 8s in the 1/8th, or mid to high 12s in the 1/4, with good traction.
Old Jul 22, 2005 | 03:25 PM
Car: 1971 Camaro
Engine: 427
Too much injector, really? The prom was burned for me by another member. I was thinking about putting a bigger cam in, but I am going to build a new short block in the near future anyway, so wasn't sure if I wanted to go trough the trouble.
What if I hit it with a 150 shot?
Old Jul 22, 2005 | 05:03 PM
brutalform's Avatar
Well now, a 150 shot is a whole different approach. If you can get your combo to go 13.00s, a 150 shot should put you in the 11.70 range. I have a few friends that did this. Their 13.00 N/A run, usually netted them 11.70s on the juice. This was with S/R equipped 350s.
Old Jul 23, 2005 | 08:10 AM
Car: 1971 Camaro
Engine: 427
Old Jul 28, 2005 | 09:14 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
It took a hotcam to get me a 8.1x 1/8 miles with everything else being similar.
Old Aug 1, 2005 | 04:41 AM
firedawg225's Avatar
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
here is my setup and i ran a 8.4 with holley's 383 SR tune no ajustments and street tires.
383 Stroker w/Holley Stealth Ram
Chevy Small Block 350 2 bolt one piece seal
Holley Stealth Ram with 30lb injectors
Commander 950 Computer
Eagle Internally Ballanced 383 rotating assembly B13052L
SRP pistons SRP138103
6.0 inch Eagle I beam rods with ARP bolts 103523750I
Comp Cams Custom grind cam
Duration @ .50 224 230
Lobe lift 335 340
Lobe sep 112 centerline 108
64cc Aalumnium Heads w/angled plugs
Comp Cams Pro Magnum 1.52 Roller Rockers
Holley Small Cap Distributor 890-160
March Pulley setup 22061
1993 Chevy Caprice Cop Car Alternator
Old style long standard rotation water pump
Stock 1992 steering pump
Lokar brackets and cables
Probulit Automatics 700R4 Tranny
ACT 9.5' Converter 2600RPM stall
DynoMax Coated Headers
Crane HI-6 Ignition system w/L92 Coil
K&N Air filter with crome lid
Accel 300+ 8.8mm Ignition wires
DynoMax Cat Back system
DynoMax Ultra Flow muffler w/ 3 1/2 crome tips
PermaCool 16" Fan
3 Core Radiator
Grant Black Steering Wheel
Wonder Bar
New Shocks and Struts
Upgrades to a 3.73 rear with a Zexel Torsen Carrier
Kumho 711 Tires
Spohn 700R4 Tranny mount w/ torque arm and drive shaft loop
Spohn Adjustable LCA
Spohn Adjustible Panhard Bar
Spohn Subframe connectors welded in
Trash 3" Driveshaft (210)342-6622
New 1/8 mile Track Times
R/T .905
60ft 1.973
MPH 80.63
ET 8.430
this may help
Old Aug 4, 2005 | 08:59 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
firedawg, next time just post up heads, cam, intake, and cubes. Lets keep it simple.
Old Aug 5, 2005 | 01:22 AM
Car: 1992 Camaro RS
Sorry the only reason i did that was ET aren't just about motor. It's all about suspension, motor, tranny, rear end gears, and even weight reduction. If the car won't hook up the car will be slower, motor has no power it takes longer to go down the track, auto/manual makes a different, rear end gears lower higher gears can change how fast you accelerate or faster you go, and also less weight means less weight for the motor and everything else to move.
diana227vegas
Jul 8, 2016 12:27 AM
1986Z28OWNER
Dec 13, 2015 10:19 PM
LittleFranks
Sep 17, 2015 12:22 PM
blackroc68
Sep 1, 2015 08:01 PM
GVMV
Aug 16, 2015 08:01 PM
