Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
distributer wireing
Old Feb 10, 2006 | 11:39 AM
blackroc68's Avatar
distributer wireing
Im installing a holley stealthram, im going to A smallcap distributer from a large cap distributer.Could someone post the wireing?? thank you
Old Feb 10, 2006 | 11:58 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
It's the same color wiring. Just get the pigtails and enough wire from a donor car and solder it in.
Old Feb 10, 2006 | 01:13 PM
blackroc68's Avatar
no it isnt ! 4 wires on output of large cap 5 for smallcap, a pink and white to the coil input on distributer 5on output of distributer
Old Feb 10, 2006 | 01:37 PM
Car: 86 T/A
Engine: HSR 355
Yeah what would I know on the subject after finishing the same conversion last month...
(PS there's 6 wires on the output of a small cap, 4 on the main plug and 2 that goes to the coil)
Old Feb 10, 2006 | 03:07 PM
blackroc68's Avatar
Mine has 7
Old Feb 10, 2006 | 04:14 PM
Car: 86 T/A
Engine: HSR 355
You got me, I don't know how to count...
Anyone else want to chime in?
Old Feb 10, 2006 | 11:08 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Goes like this, Trace your colors, mine are different cause I did it my way
Old Feb 10, 2006 | 11:10 PM
JP86SS's Avatar
And to finish this off
I went through this a few months ago.
The "Black" side plug on the coil is basically impossible to find.
One place that I did find was outrageous for the cost.
Grey Side of Coil
GM# 12101896
Delco # PT166
Car-Pak #94-7305
Black Side of Coil
GM # (does not exist in catalog anymore)
Car-Pak # 94-7306
Black side connects to here (best to locate this part at JY)
Distributor 2 wire connector
(Same as Coolant Temp Sensor)
GM # 15306195
Delco # PT-169
Distributor 4 wire connector
GM # 12126487
Delco # PT-757
Car-Pak # 89-6707
Car-Pak manufacturing
1401 Axtell Rd.
Troy MI. 48099
(248)-280-1401
They only sell through this place
http://www.autobodysupplies.com
Look at section 11, subheading "I"
Old Feb 10, 2006 | 11:16 PM
JP86SS's Avatar
And just in case...
If you are putting an MSD 6A box in, This is how it goes.
Old Feb 10, 2006 | 11:41 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
accel made an adapter...came with a used gen6 dfi setup
it's a leftover, PM if you need it
Old Feb 10, 2006 | 11:46 PM
JP86SS's Avatar
That is the "reversed adapter" in the diagram above.
Be careful that the pinout is not reversed like shown. Had me scratching my head as to why they did that.
Old Feb 11, 2006 | 12:04 AM
JP86SS's Avatar
Guess I can't count either Stuff above is for 8 pin.
Here's a 7 pin diagram in case you only do have 7 pins.
Old Feb 11, 2006 | 07:08 AM
blackroc68's Avatar
THANK YOU that wireing is just what i was looking for. The main problem i had is i connected the wires that were the same color,the wires i had left didnt match the other wires
Infested
May 22, 2018 11:56 PM
db057
Sep 4, 2015 07:57 AM
Bryan F
Aug 27, 2015 07:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
pimprs
Aug 24, 2015 11:20 PM
